Question about Poulan Pro PP3816AV 38 Cc 16" Anti - Vib Chainsaw
The trigger sticks in the open position on my pp3816. Can this be repaired or is a new hande required
    Genius:
  • 1,114 Answers
Possibly gunk has accumulated inside the handle,preventing the trigger from moving correctly. Try spaying WD40 or other lubricant inside the handle around the trigger. That may loosen up the trigger. Also, try the WD40 on any part of the linkage that you can locate.
Posted on Jun 27, 2009
Trigger is sticken
Glue guns are made mostly out of plastic, and are really not made to be repaired.
May 10, 2015 | Crafts & Hobbies
Loss of pressure
You will probably find the loss of pressure is bad pump seals maybe even worn pump pistons. The problem is that it cost as much to repair these pump as it does to replace them with a new warrantied unit most times. Larger commerical pumps are still fairly reasonable to repair but the replacement costs are coming down too.
Jan 15, 2015 | Garden
Fingers sticking togetherwhen working
I'm assuming that what you're trying to describe is that the joints in your fingers feel like they are locking in a bent position after doing work. If this is so, it is very likely that what you're experiencing is trigger finger. The tendons that cause your fingers to be able to bend run through small openings in the bone. The tendons can develop small nodules or bumps on them that are larger than the opening the tendon runs through. When you bend your fingers the nodule passes through easily, but is difficult to get it back through in order to straighten out your fingers. This problem can become worse and very painful without treatment or care.
Mar 22, 2014 | Health & Beauty
Technics SL-P111 door wont open!?
Some units require a draw be in alignment with the rest of the system in order for the mechanism to get into the right place to trigger skeleton switches or small microswitches. You hand upset that positioning and the only way it will work now is to get the mechanism aligned so that all is happy. This will require a Technician who is capable of working on these units. I have seen this on many brands- the better unit are self aligning but there were some that were made like yours that have trouble.
Sep 21, 2012 | Technics Audio Players & Recorders
My dewalt 18v cordless drill trigger is sticking in the on position. The model is a dc 988
In most cases triggers either work or they have to be replaced. There are no repairable parts in them and lubricating them usually results in more dust sticking to them and the plastic breaks down from the lube and the problems get worse. Try blowing any debris out of the trigger with compressed air while working the switch. If that doesn't work, the replacement trigger for your drill is part number 152274-22 and is fairly easy to replace. Shop around on the web for the part as they run $50 to $70 plus shipping.
May 10, 2011 | Garden
Arrow TR 550 heats up fine but glue stick won't feed by the trigger. If I push the stick with my hand glue does come out, but the trigger seems to "slip" on the glue stick. Any ideas?
The trigger probably really is slipping on the glue stick. If you've changed the type or size of glue recently, try changing back to what you were using, or just something else. Maybe the glue stick is too small, or too slippery for the gun. If not that, then it's a mechanical problem. There are some screws on the side of the gun. With it unplugged and cool, take them out and open the case. It might be stuck together with some internal connections as well as the screws, but jamming a flathead screwdriver in them can usually wedge them apart. With the gun open, move the trigger and look for the parts that move with it in the area where the glue stick goes. If you can find something to attach to these parts to make them just a tiny bit longer, do that. The parts that grip the glue have probably worn down or just don't fit, and the fact that you can tell the trigger is slipping means that it's probably very close to grabbing, but not quite close enough. Any little extension to the grabbing parts should do, but be careful not to block the path of the glue.
Feb 28, 2011 | Heavy Duty Arrow Pro Glue Gun Tr550
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
Need brake circuit diagram for 1991 chrysler new yorker
1991 Chrysler New Yorker Auto Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): Red and Pink
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Dark Blue
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Black/Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Positive Wire (+): Orange/White Or Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: In Drivers Kick Panel
Dome light Supervision Wire: Use Door Trigger (Requires Relay)
Dome light Supervision Wire Location: N/A
Trunk Release Positive Wire (+): Black/White (Requires Relay)
Trunk Release Positive Wire Location: At Trunk Release Switch
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Relay In Fuse box
Tachometer Wire Negative Wire (-): Black/Gray
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch above Brake Pedal
Factory Alarm Disarm Wire (-): Light Green/Orange
Factory Alarm Disarm Wire Location: In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Thank You for contacting Fixya.com
Aug 03, 2009 | 1991 Chrysler New Yorker
Water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Poulan Pro PP3816AV 38 Cc 16" Anti - Vib Chainsaw Logo
143 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
