Question about Lincoln X2471 2 YR EXTENDED WARRANTY FOR PM 140C
Cannot get machine to turn off with killswitch
Miller blue star will not turn off with toggle switch
    Champion:
  • 225 Answers
Check toggel switch,sounds like it is stuck in closed position.
Posted on Jul 02, 2009
What size motor came out on the miller blue star 2e welder
Depending on serial number, Miller started out with Kohler manual start, Kohler electric start, and then Tecumseh electric start. They ended the series with a Tecumseh OH160, miller part #070732. I have included the manual. https://www.millerwelds.com/files/owners-manuals/O424E_MIL.pdf
Sep 11, 2017 | Miller Welding Tools
I am looking for a starter switch for a Miller Welder. Blue Star 2E, Serial # JA438286
Miller switch part # 011611 you can order through your nearest Miller dealer.
Oct 11, 2014 | Welding Tools
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
2010 harley davidson changed battery and now won't start
Put it in neutral and pull the clutch in. Kickstand up and Killswitch in the normal position. Turning the key off and back on will reset the FI Light. Make sure that battery is fully charged first. Low voltage might not fire the injectors. Let us know how it goes.
Heck, toggle that killswitch a half dozen times.
Jul 04, 2012 | Motorcycles
Wiring diagram for miller bluestar welder ser. JE817646
http://www.millerwelds.com/service/ownersmanuals.php?model
If you see a model that is close in description in the Blue Star models, such as a "145" the wiring diagram should be close if not the same. Otherwise select from the list the Blue Star with the same engine type as yours.
The If the tag is not damaged, and truly a JE series, you can download all the Blue Star manuals to find the one that has your serial number in the range. Miller is good with manuals, but sometimes the cross reference to just serial number does not work.
Dec 17, 2011 | Welding Tools
Camry 1995 AS-9903 Alarm Problem
LOOK FOR A TOGGLE SWITCH IN DRIVERS KICK PANEL. ONCE FOUND TURN KEY ON THEN FLIP SWITCH.
IF ITS A PUSH BUTTON SWITCH THEN TURN KEY ON AND THEN HOLD THE BLACK VALET SWITCH DOWN FOR 8-10 SECONDS.
DONT LET MORE THEN 5 SECONDS GO BUY BETWEEN STEPS.
Nov 25, 2009 | Audiovox - AS-9903 - Six Tone Car Alarm...
I have a miller blue star 6000. I started it up but its not putting out any power.
By any chance has this generator been sitting for a while, or been dropped? That's a common symptom. The generator has lost its' residual magnatism. The exiter field needs to be flashed. Either follow the instructions in you user manual or see this link:
http://www.dieselduck.net/machine/03%20electricity/flashing_generator.htm
Avoid this problem in the future by running the generator with a load on it for 10 minutes or so every once in a while.
Dec 25, 2008 | Miller Blue Star 6000 Elec Start 120V DX,...
Lincoln X2471 2 YR EXTENDED WARRANTY FOR PM 140C Logo
70 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
