Question about Fein 9-55-13 Turbo II Bagged Canister Vacuum
After lending to my sister for some drywall sanding. She was removing popcorn from a popcorn ceiling, the vacum now runs much louder and as though it is clogged.
  • 66 Answers
Try changing the filter.
Posted on Feb 16, 2010
I am vacuuming spackle dust from sanding walls and my electrolux canister continues to open. What should I do?
Fine dust from sparkle will clog a bag or filter very quickly even though the bag is not full or even close to full. The air can't pass through the bag so it is popping the door open. Drywall dust can ruin a vacuum motor very quickly. I use a shop vac style vacuum with a cartridge filter that still clogged up after just a few minutes of vacuuming the dust but I can take the filter outside and hit it against something and use a small soft brush to clean it.
Jan 28, 2018 | Electrolux Vacuums
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
Having lots of drywall dust, vacuum cleaner is connected and hose is having suction but sander is kicking dust all over the place. Can you help .
Wet some old bed sheets and lay it on the floor where you are sanding.Sand by hand.Using a power sander will not only damage the wall;but will also damage both the vac and sander
Jan 21, 2018 | Vacuums
I have a model 484 709 UPC 792145330547 The fan/light is close to ceiling (instalation). Their is supposed to be an "o" ring to remove the fan/light from the celling. I cannot find it!!! ...
Remove the cowl at the ceiling by removing the screws in the cowl (very close to the ceiling). Use caution in removing them as the weight of the fan may be carried by these screws. Depending on the style, though, the weight may be borne by supports beneath the cowl. Either way, this will get you access to the wiring, allowing you to change out/remove the fan. If the fan and cowl are together, and close to the ceiling, there is usually a method of hanging the assembly while the wiring connections are made during installation. Look for a hook that the screw hole will go over, supporting the fan.
Best regards,
--W/D--
Jan 19, 2011 | Vacuums
Dyson DC17 started making a louder overall noise
Hi there, from your description it sounds as though the machine has a blockage.
Try following the online diagnostics in the Support section on our website at www.dyson.com. Hopefully this will help you locate and remove the blockage causing this.
If you need any further help or advice, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 05, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Loud screaming noise when running
The vacuum is clogged. Disassemble it as much as you can and you will find the problem.
Ray
Dec 15, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson dc07 animal bagless
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Nov 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Fein 9-55-13 Turbo II Bagged Canister Vacuum Logo
222 people viewed this question
Top Fein Vacuums Experts
Bill Boyd
Dan Apthorp
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
