Question about Saniflo Sanibest Grinder Pump Only 013
I bought a new sanibest AND WHEN I WENT TO INSTAL IT THERE WAS FLUID IN THE GRINDER. IS THIS COMMON
    Sergeant:
  • 399 Answers
Could be left from quality testing
Posted on Nov 14, 2009
Where can I by replacement for the concertina rubber tubing that links a toilet to the Sanibest macerator
You should be able to purchase this at any local hardware store.
Lowes, Menards , or Home Depot. They may have to order it but I am sure that if you take the old parts they can make you a replacement if they do not have the direct replacement hose there.
Oct 16, 2013 | Saniflo Sanibest Grinder Pump Only 013
I cannot get the top w/ gasket back on a sanibest after servicing the macerator
Make sure the gasket and it's grooved channel are clean also the inside lid lip where the gasket sits on should also be cleaned. Once all parts are cleaned properly install gasket to inside lid lip make sure it seats to the very bottom of the gasket. If it tends to fall off when installing apply a tick coat of petroleum jelly( Vaseline) to help hold it in place while installing. Hope this helps it did it for me
Jun 06, 2011 | Saniflo 013/003/005 Sanibest Toilet with...
Every time the float operates the switch to on the fuse trips out?
It sounds like the impeller for the grinder pump has something fowling it and you will need to pull the pump or at least clean it out.
Mar 04, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
I have a new saniflo tiolet when flushed the paper stays in the bowl untill the tiolet has been flushed 2 or 3 times
the unit sounds like it is not vented properly check vent connection if there is a venalator on it that dosent work it has to be vented to attic the pump has to vent in and out not just in that the ventalators are designed for
Nov 16, 2010 | Saniflo Sanibest Grinder Pump Only 013
A new saniflo working perfectly for first week has now stopped working. the unit does not run at all
y have a reset butto which may have pinged out try resetting it or it may have overloaded due to a blockage never put paper or towles in them water expanps them and causes this problem
Aug 02, 2009 | Saniflo Sanibest Grinder Pump Only 013
Grinder wont turn and toilet not flushing
Disconnect the power and pull the pump out and examine the pump. Simple and easy!
May 23, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
My sanibest system is working but not pumping the water - any suggestions?
Possible blockage in dis charge pipe, not something i'd like to investigate myself!!
Jan 23, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflo Sanibest Grinder Pump Only 013 Logo
237 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
