Question about ASUS SiS Chipset P4S333-M (90-M8L39B-E0UAY) Motherboard
Computer dont work, and this ISNT FREE !!!
Dont know where start button wire go on mother board
Not start & windows xp
Posted on Oct 20, 2012
  • 721 Answers
Www.asus.com ,go to support,downloads & get the pdf manual
Posted on Jun 27, 2009
Is there a reset button on the mother board. Or is there a reset. Button on the moniter it keeps on is playing no signail
no and no
no signal means that the connection to the computer is not there (cable not properly in or broken wire ) or the mother board is not working the VGA section of a push in board or the mother board proper
have a computer repair shop check it over for as proper diagnosis and a quote
May 04, 2016 | Computers & Internet
Computer power supply does not work
Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Feb 09, 2014 | Antec TruePower Quattro 850-Watt Power...
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
PROBLEM WITH AUDIO DEVICE
the front port wire is not connected to the mother board.please refix it .
Jan 13, 2009 | Computers & Internet
My computer doesnt function right
then the problem lies in the main board..aka mother board and it needs to be replaced.....
Jan 07, 2009 | Computers & Internet
Computer Case ULT33180 Powers down about 4 seconds after started
Ive done something similar, I took the CMOS battery off the motherboard and put it back in after about a minute to reset the bios. Unplugged the power supply from the motherboard and flipped the power switch on the back of the power supply (on and off a few times) and plugged the power connector back onto the motherboard. I know it sounds like an odd way of fixing this problem but has worked for me.
Jan 03, 2009 | PSA E-Torque (ULT33180)
Will not power up unless I move the display back and forth
Sorry I lost my password. This is a common problem with the 610 and other laptops. This repair is not for a Novice. Please get the maintance manual from dell go to dell support its free and know the disassembly procedures for tearing your laptop apart. Remove the bezel on top of your keyboard. The start button is on a small pc board. The problem is on the connector on the bottom of this board that commects to the Mother board of your computer. Remove all external, and plug in devices to your laptop. including the battery. After removing the keyboard, the top plastic cover, the start pc board, ect. you can see the connector from the start board that connects to the mother board. Look carefully and gently see if this connector is loose. The mother board connector is supported by 2 silver looking braces on each end. gently see if they are loose. I bet that one end has broken loose from the mother board. re solder the loose end to the mother board. be careful not to damage anything as I said this is not for the novice. (with the laptop in pieces put the startup pc board back in, temporairly put the battery in and push the start button. If the led's glow, this is where the problem is. While your laptop is apart check for dust ect. You may need to remove the heat sink , and a back support brace to get to the mother board connector to re solder it.
This has been a problem on 3 of my friends laptops Pushing on a button harder and harder doesn't solve the problem. It's not the button .Now you know the rest of the story.
http://support.dell.com/edocs/system/latd610/en/sm_en/index.htm
Hopes this helps just remember where all the extra screws go when you re assemble your laptop
Dec 11, 2008 | Dell Latitude D610 Notebook
Psp screen wont work with my old motherboard
ok i know whats wron here i just need to replace the mother board
Dec 04, 2008 | Video Game Consoles & Games
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Aug 14, 2008 | E-Machines eMachines Desktop PC
ASUS SiS Chipset P4S333-M (90-M8L39B-E0UAY) Motherboard Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
