Question about Dell Dimension™ E510 PC Desktop
I have dell dimension e510 and i got a steady amber and the 2-3-4 are lit up green. i cant get comp to start up what is up with my comp
  • 102 Answers
See if this will open for you
http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm#wp1114195
look for the
Diagnostic Lights that should give you an idea whats going on
Posted on Jun 28, 2009
How do I fix a dimension E510 with a solid amber power light?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Dell Dimension E510 PC Desktop
Dell Dimension 3000 will not power up. Solid amber lit stays on. Any help would be accepted.
  • If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
    • Remove and then reinstall the memory modules.
    • Remove and then reinstall any cards.
    • Remove and then reinstall the graphics card, if applicable
Refer to the link: http://support.dell.com/support/edocs/systems/dim3000/en/SM/adtshoot.htm#wp1043338
Jan 26, 2011 | Dell Dimension 3000 PC Desktop
Tower power button flashes amber but will not start
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Dell Dimension power button flashes amber and will
open up your system get a can of air and blow all dust away could be an overheating fault
Amber lights at the front of my dell dimension cant boot up
This can mean various things, but I've had a few of these happen and it's usually caused by a failed power supply. Calling their tech support they will ask you to remove memory and disconnect hard and optical drives then try again. If it still is amber, it's a power supply.
Oct 11, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension 2400 with steady amber power light and diagnostic lights of ABC green and D off. What could be the problem?
Steady amber power LED is indicative of a problem with the motherboard. Remove all external connections except power, remove all PCI Cards, ram, disconnect power from all drives, turn on see if power LED is still steady amber. If it is, more than likely the motherboard has a failure. Also check to see if the CPU heatsink is firmly seated (The plastic retainer has been known to fail causing the CPU to overheat)
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Steady amber Power light
You are looking at a new mother board. I would take it to a certified technician shop, so they can run a stress test on the motherboard for final benidiction.
Aug 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Amber light flashing on dell e510 won't power up
Try reseating the memory sticks.
2. Remove 1 - try to boot
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension™ E510 PC Desktop Logo
216 people viewed this question
Alun Cox
