Question about Bosch Axxis WTL 5410 Electric Dryer
Dryer drum will not turn
Bosch Axxis WTL 5410 Electric... when turned on, the drum will not turn and there is no sound - is there a reset button?
  • 1 more comment
  • Anonymous Jul 29, 2008
    All the lights go on, but when the start button is pushed nothing happens. I tried different cycles and tried turning the dryer off then on again , retrying the start, but still nothing happens, How do you check the door latch or start button?
  • hudhome Jan 21, 2009
    Electricity and all lights are on. I have replaced both 15 amp fuses and hit the red reset button. A couple of weeks ago we had to start drying using the time settings rather than the drying settings. Yesterday everything stopped rotating. Wish I had never bought this combo
  • Anonymous Mar 16, 2014
    remove motor from bosch axxis dryer
  • 36 Answers
Sounds like a power promblem to me check at out let for 220 volts if you have it there first turn circete breaker off then on try drier if that dont get it check for power at outlet with meter if 220 is there after unplugging drier check cord at back of drier at terminal block if all thats ok then you have a bad door switch a bad start switch or a bad thermal limiter last and rare bad drive motor
Posted on Dec 29, 2007
2 Suggested Answers
  • 11 Answers
SOURCE: Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Posted on Mar 24, 2009
My dryer WTL 5410 electric condensation dryer is cutting on and off.
this is normal operation it turns the drum one direction then the other this is because of the way it condensates
Apr 06, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Where EXACTLY is the reset button on the bosch wtl 5410? behind the lima bean panel? in the little white box upper left? where EXACTLY is this frigging switch?
sometimes, it's behind the panel where all your switches, etc. are - in the top front of your machine. First, disconnect the cord from the electrical outlet before you do this, or at least turn off the circuit breaker.
Mar 13, 2010 | Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
My Bosch Axxis WTL 5410 will turn on and spin but no heat comes out of it. I cleaned the heat exchanger and wiped down the moisture sensors inside the drum, but still can't get heat out of it. I've read...
How long have you had the dryer (is it still under Warranty) and do you have the owner's manual and have you looked in it for a solution?
If not then you can contact the manufacturer on line to pose the problem to them.
There may not be a reset button on it at all. If there isn't then it is more than likely the heating element and you will have to replace it.
Oct 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch TD WTA3000 can't find reset button
YOU NEED take out hood cover 210162 in the back dryer.
Oct 06, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Re-set button location?
you need to remove the back panel the smaller one that covers heater matrix you will find a thermostat with a red reset button on it when you push it it will click and reset however you should find out why this happened before you use it again as it only does this if it overheats.
hope this helps
Jun 29, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Mar 24, 2009 | Dryers
Bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Jul 25, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
393 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
