Question about Migali Refrigerated Prep Table Three Section 88in W 26 Cu Ft
Freezes up under fans - Migali Refrigerated Prep Table Three Section 88in W 26 Cu Ft
  • 4 Answers
Shut it off for a day & let it defrost then run it keeping an eye on the cap tube if it fresses it's low on gas aslo check the dryer it should be warm if it's cold it's blocked i hope that helps
Posted on Jul 24, 2009
    New Friend:
  • 7 Answers
Check the temp. control if it is on the right settings,dirty coil,one or more fans not going if all of the above ok short of gas or blockage
Posted on Jun 27, 2009
Refrigerator freezes sodas in the fridge part
May be simple as dirty condensor coil try looking under the bottom where the compressor is there is a coil with a fan blowing on it. Try cleaning the coil and make sure the fan is working
Aug 10, 2012 | Refrigerators
If i set the temp to low on my window air conditioner can it cause the unit to freeze up
Under some conditions, it could freeze up. High humidity levels can cause the coils to freeze. Not cleaning the air intake filter regularly, can also cause the coils to freeze. However, most window units can not be set below 65 degrees. But, in high humidity, it could freeze at that temp.
If you want to avoid the possibility of the coils freezing, operate a ceiling fan or other small fan as fast as comfortable. This keeps the cool air moving a generates a wind chill that fools your body into thinking it's cooler than it really is. Doing this will keep you from having to turn the AC way down and thus, save on energy cost.
I hope this has helped you and thanks for choosing FixYa.
Sep 08, 2011 | Heating & Cooling
My samsung rs267lash, the coil inside the refrigerator section keep on freezing up also just under the fan and it's stoping the fan
Most likely the defrosting heating element has burnt out and needs to be replaced. I know it seems contradictory but modern refrigerators rely on a heating element cycling on a couple of times daily to keep the condenser core from freezing up.
Please rate my response.
Jan 15, 2011 | Refrigerators
Laptop freezes after only a minute of being on
If you bought it new, it's still under warranty. Contact the store where you bought it.
Otherwise, freezing machines that stop working after a short time but will turn back after sitting a while are usually having a heat issue. Bad CPU fan, bad video fan, etc.
Jun 24, 2010 | eMachines eMD620-5133 Notebook
MY FREEZE DOES NOT FREEZ BUT IS COOLD DOES IT NEEDS GAS
When the compressor is running, two fans should be running. One inside the freezer compartment that moves air over the evaporator coils. The other is under/behind the fridge that cools the condenser coils.
If the fan on the condenser coil (the one under/behind the fridge) stops working, the system cannot dissipate the heat from those coils, and thus cannot sufficiently cool the inside of either the freezer nor fresh food compartment.
On mine, when the condenser fan failed, I noticed right away. The front face of the wall separating the compartments became very hot. Extremely hot.
Apparently the refrigeration system is designed so that waste heat keeps condensation from forming where the magnetic gaskets on the door need to seal. When the condenser fan failed, there was too much waste heat (because no heat was being dissipated from the condenser coils by the fan), thus making that gasket-sealing area very hot.
If it is your condenser coil fan, you can relieve the problem temporarily by removing the bottom back panel from the fridge and aiming a box fan (a regular room or window fan) at the condenser coils. This will circulate air over the coils, thus removing heat from the coils.
Jul 29, 2009 | GE GSH25JFR Side by Side Refrigerator
My laptop is freezing for hours at a time.then i shut it down,and retart but it also takes for ever,some times all day is this due to the freezing or is this another problem .and can it also be ovet...
you need do some thing follow:
1) clean the cpu fan and sink(around there dirdy)
2) check the cpu fan is running and stop ok when power on if running go next
3) check the cpu fan, is there any running and stop then see it run again before the laptop freezen?
4) if the fan not running again before freezen that your fan control circuit out of work on the motherboard need to repair
5) if the fan running control ok that the fan can run and stop and run again. you have to add a EXT cooling base under the laptop
hope to help you solve it
May 09, 2009 | Dell Latitude D600 Notebook
System temperature too high
Do you still have your manual? If not download it from Gigabyte at this link:http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2637
Enter your bios & open manual to page 51, "PC Health Status". Here you can monitor the CPU temp, system temp & CPU fan speed. Notice the manual shows the example of system temp to be 30degs C & current CPU Temperature is at 47degs C. One would think these temps are reasonable. My CPU fan runs between 3308Rpm & 3341Rpm. CPU @ 41deg C & MB @ 31deg C. AMD 64 X2 Dual Core 4200+ 2.21 GHz.
Suggest you try this. If your running Win XP. Open system properties. Click the Advanced tab. Click the settings button under
Startup and Recovery. Remove the check mark to the left of, Automatically restart. Windows should provide an error message if & when the system freezes. This will help in finding what is causing the system to freeze. If your CPU fan is running under 3000Rpm you might consider buying a faster fan or add a case fan to the side of the case to help bring in fresh air to blow onto the CPU fan & PCI-Express card. Here is a decent lace to look for case fans: http://www.xoxide.com/casefans.html
Keep me up to date andr_zero.
Mike
Dec 17, 2008 | Gigabyte GA-P35-DQ6 Motherboard
Water Freezing Under Evaporator Fan
the defrost termination thermastat is what is cutting of before
time
it is located on the top of the evaperator in the freezer
part number is wr50x10153
the defrost timer is located in the fresh food section in the frount housing that the controls are mounted in
change the defrost termination thermastat and it will fixya
May 05, 2008 | GE PTC22SBMR Top Freezer Refrigerator
Check this site for more info on where the defrost timer might be.
Migali Refrigerated Prep Table Three Section 88in W 26 Cu Ft Logo
141 people viewed this question
Top Migali Refrigerators Experts
ray gallant
Jojo
Dennis Boxerman
Are you a Migali Refrigerator Expert? Answer questions, earn points and help others
