The fuses blow and then the water drains from the pressure tank
SOURCE: water pump for 4" well blowing fuses
Make sure you are using correct size fuse. If you are and there are no problems with the wiring to the pump. It has failed and needs to be pulled and replaced.
One check you can do is measure the resistance between the leads going down to the pump. Should be low resistance BUT NOT ZERO. I'll say anything over 2 but less than 15 ohms is good. If any two leads reads zero, it is a bad motor on the pump. If any two read infinity, the wire is broken or it is a bad motor on the pump.
SAFETY FIRST!!! Make sure you turn the power off before doing any resistance checks and you must disconnect two of the three wires before checking (if only two wires, just one).
