Question about Initial DTV-262 26 in. TV/DVD Combo
Can't change mode
Can't change the mode, channel, volume etc. Can only watch video's because that's what mode it's stuck in.
0 characters
1 Points
Power went out while VHS video was playing. Unit will power on, but will not play or eject.
Going to have it opened up---likely the tape was loaded and got wrapped up on something inside the mechanism.
May 23, 2012 | Combination Televisions
I can't get the VCR mode off the TV screen in order to watch TV.
try looking for either "source" button on the remote or ""input" choice. also you can try using the channel changing buttons, sometimes you can get out of vcr mode by just going up or down on the channel selector
Mar 16, 2011 | Philips Magnavox 20MC4304 20 in....
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Auxillary mode!
I'm sorry, but you need the original remote or a universal that will activate the input on the tv.
Dec 15, 2007 | Sansui COM312AD 13" TV/VCR Combo
"Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Oct 31, 2007 | Combination Televisions
Channels locked
this worked for our emerson....go to menu....go down to v-chip set up..chick on the volume button.....this should take you to something that will say tv ratings...again click on the vol. button. when I did this it showed that all channels were blocked.. again click the volume button and it should change it to view.. if it works this way for you then just click menu and you are done.
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Remote doesn't work
According to Mintek support you should unplug your set for 30 minutes which is a reset/rebooting process. Then plug it in and hold the DVD eject button for 5 seconds [at least]. The DVD should eject unless there is another problem. If it doesn't eject then call Mintek support at 877-646-8358 for help. They told me you have to send the TV to them and they'll send a new one. If you have to do that then make sure you tell them you want your DVD returned when they get it out. Good luck.
Nov 22, 2006 | Mintek DTV-263 26 in. TV/DVD Combo
Initial DTV-262 26 in. TV/DVD Combo Logo
Top Initial Combination Televisions Experts
Steven Wander
Steven Wander
Jim Goldsmith
Jim Goldsmith
Are you an Initial Combination Television Expert? Answer questions, earn points and help others
