Question about Bemis Home
I am trying to remove the seat bolts of my Bemis low-flow (low profile) toilet. The bolts are turning and pull out a 1/2" or so, but they will come out no further. Clearly there is a bolt on the end, preventing removal. I just can't get to the bolt. It is likely inside the single piece porcelain john. How do I get the bolts out in order to replace the seat?
  • 224 Answers
You need to hold the bolt with the screwdriver, then there is a nut underneath that you need to undo. One on each side of the seat.
Posted on Jul 04, 2009
T am trying to remove a Bemis sattite toilet seat. How do I do it?
if you cannot get it to unseat you can take a hacksaw and carefully cut the bolts from under seat on top of toilet base easiest way to remove seat
Sep 11, 2015 | Bemis Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
Hi there, I'm hoping you can help me to locate someone who can find a bolt for a bemis toilet? Thank you
if there is something model specific that makes this bolt hard to find then call bemis and they will most likely just send you one. most products have a lifetime guarantee. if it is just a seat bolt that you need you can get replacement seat bolts at any hardware store such as lowes or ace hardware.
May 19, 2011 | Home
WHERE CAN I GET REPLACEMENT SEAT AND COVER BUMPERS FOR MY BEMIS TOILET SEAT?
If the seat is a molded wood seat, you can usually get bumpers by contacting Bemis Customer Service, 920-467-4621. The bumpers on plastic seats are not replaceable because they are part of the seat.
Mar 26, 2011 | Bemis CHURCH Elongated White Slow Close...
What toilet seat hinge replaces Bemis elongated closed front toilet seat (plastic/not a bar/pair of hinges) and who sells? Can't believe Bemis does not support to proclaim hinges set in warm plastic...
The hinges and bumpers on plastic seats are not replaceable. The bumpers are molded in and the hinges are installed with special tools while the plastic is still warm.
Sorry but that's way Bemis does things and is way most good Plumbing shops will not buy or sell them.
They were not like that untill they started having their seats made in China however this may help you http://www.bing.com/shopping/search?q=bemis+toilet+seat+replacement+parts&FORM=HURE
http://www.bizrate.com/plumbing-supplies/oid1620858646.html
Mar 11, 2011 | Bemis 7MCLRDRCT NA Elongated Toilet Seat...
The seat of my Toto Zoe Washlet is breaking. I would like to replace it. The manufacturer does not carry it. Where can I buy one?
Companies like Bemis make seats for other companies. Find out whether your seat is elongated or round and go to your nearest hardware store and order one through Bemis. IF it is of COLOR, then write down any codes inside your tank before you go to your nearest store. This may help the associate find the right color through Bemis.
Nov 30, 2010 | Toto Zoe Washlet 1-2 Pc Round/elongated...
Water flow problem
2 things it could be. Bad flapper seating or back siphon.
1) visually check the flapper. Is it worn, cracked, or not fully seating because the chain might be too long and preventing a good seating?
2) IF the flapper is good without anything blocking it open there, then you have back siphon. Make sure the small hose that goes from the fill valve into the over flow tube has an high arch. If the arch is too low, after the water is cut off the gravity will back siphon water out of the tank.
Mar 19, 2010 | Home
I have a nice white Bemis toilet seat on which the
most hardware or home stores carry replacement hinges also online sites such as the hardwarestore.com sells replacement -larsen 2pc white hinge part 14-1039 $5.99 ace hardware,home depot, lowes, local stores
Jan 22, 2010 | Bemis 200 Slow Regular Toilet Seat, White
Removing rusted nuts from bolts to replace toilet seat
Try:
* Penetrating oil...let it soak at least 1/2 hour
* If the nut is stripped, try either grabbing it with vice grips
* If all else fails, either grind it off, or use a nut splitter. Nylon is pretty soft, so it should be relatively easy to break
Apr 26, 2009 | Bemis 7MCLRDRCT NA Elongated Toilet Seat...
Home Logo
247 people viewed this question
Top Bemis Home Experts
jdthefixer
john h
Are you a Bemis Home Expert? Answer questions, earn points and help others
