Question about Carrier Heating & Cooling
Air con lines are iced up - Carrier Heating & Cooling
    Sergeant:
  • 340 Answers
1 Change you air filter 2 Dirty evaporator your going to have turn it off to unthaw if after that and their is good air flow id call for service low on freon leave the fan on, on .cooling off good luck . Tom
Posted on Jun 27, 2009
I have an Air-con air conditioner and heating system
Check your filter, if it's clean check the condensate drain to be sure it's draining if ok your system has a leak and will need an ac tech to repair and recharge the system
Nov 28, 2013 | Air Con 9,000 Btu Split ditioner Wall...
I have an Air-con
there is not enough refrigerant on your a/c
Nov 28, 2013 | Carrier 52PQ307 Wall/Window Air...
Air con leak
Check all the line connections
Jan 12, 2013 | Air Conditioning and Heat for Acura NSX
My outside toshiba split system is leaking a lot of water
If the unit is on heat mode, the outside unit is the "cold" end... Sometimes if the ambient air temperature is very cold ( Under 5 degrees C), the outdoor unit can start to ice up. If it ices up too much, the air con will automatically go on to a defrost cycle where the outdoor unit will heat up and melt the ice. Water is then drained out the bottom.. its the opposite of what happens in the summer when the indoor unit has water running out of the drain hose. Especially on humid days..
Jul 16, 2011 | Fujitsu Heating & Cooling
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
Hi, our fujitsu air con is leaking. It is model asta09lacm. Water is dripping. This has happened to two of our 3units in our rental unit Please help
this is a common fault, is the unit iced up? if not condensate pump will have failed and over flowing and a replacement will be required if it is iced up unit may be short of gas
Jan 20, 2011 | Heating & Cooling
Air con unit has ice every whaere on the unit
Make sure all the fans are running. Check the air filters and the indoor coil to make sure it is clean. If it is still icing then get the refrigerant charge checked.
Oct 23, 2010 | Heating & Cooling
While idle cuts off when air condition is on
Solution: 1. The engine has Idle Air Controller (IAC) that is suppose to keep the engine speed at a constant (even with changing load - AC, FAN, etc.) If the IAC is broken your idle will be rough or even die.
The AC compressor places a large load on your engine.If there is a problem with your IAC(Idle air controller)which is located on the throttle body it will cause the vehicle to die when you turn the AC on.Remove the IAC and check it for carbon.If there is carbon try to clean it up with a wire brush.
2. If your air con is drawing more power than your alternator/battery is capable of supplying - you could try fitting a higher charge rate alternator and a heavy duty battery also ensure battery to chassis earth is sound and clean of rust and grime at metalwork.
3.Another reason for this is that when the air con is on, ice and water forms on the outside of the air con pump and condenser. This ice and water can spray around the engine bay and if there is any electrics that are around it can cause a short circuit.The easy way to fix this is to identify the air con pump and condenser, then spay WD40 on all the electrical components you can see in the direct area.
WD40 displaces water and will cause no problems with the cars electrics.
May 08, 2010 | 1994 Honda Accord
Why is there water dripping from the air con?
The most probable cause is a clogged drain line.
Also ensure your air filter and the evaporator coils are clean.
Let us know if this helps and good luck.
Feb 24, 2010 | Heating & Cooling
Caliber heater problems
the guy doesnt know anything about hvac if he told you that ok do a pressure test on the cooling system and make shure you havent got a pressure loss if you do there will be a leak and if your windows are foggin up id say that there is a small leak probably on a hose clamp on the heater core line is leaking or the core itsself
Jul 18, 2008 | 2007 Dodge Caliber SXT Sport Hatchback
Heating & Cooling Logo
62 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
