Question about Technics SL-1200MK2 Turntable
Static i have been haveing a very large problem with a "static" soundi have swaped every thing but still the proablem is there ive even tried bypassing the mixer and playing the turntable though the reciver but its still there it is only one table there other if fine any help would be greatful????
  • 382 Answers
It's possible that your ground wire or rca cables have shorted out. Also check where the cartridge is installed in the tonearm to see if the 4 contact pads are corroded or pushed back. Make sure the ground wire is screwed firmly into the mixer or receiver. if oyu have tried these options and still get static, replace the tonearm.
keep me posted
Posted on Nov 06, 2007
My 86 yamaha outboard will not turn over
Bypass solenoid,put jumper from pos on batt to starter motor,but could be so many things,faulty battery cables,broken wire in loom,worn starter brushes,faulty solenoid ,start in gear switch or ignition switch
Feb 02, 2014 | Clymer Marine Maintenance and Repair...
I cannot get sound on yahoo messenger pool game ive tried everything i reinstalled messenger 10 i cleared my cookies ive got the latest java and ive even tried to change profiles Ive checked my volume...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Computers & Internet
No power to the blower,is there a hiden fuse? relay swaped can hear relay working, had the blower out and tested it straight to battery and it works,what do i test next?
check the blower resister. its the thing that makes it run at different speeds. its located in the heater box and has 4 large wires going to it
Jun 05, 2010 | 1984 Toyota Land Cruiser
Kawasaki z750 2004 model when u insert key every thing comes on except the fuel pump bike seems like its getting no fuel
remove and test fuel pump relay if the fuse to it is good.try swaping it with another one like it just to see if thats it.(or using a test lead with a fuse of its own see if you can bypass the system power at the pump to make the pump work,that way its only the pump you are testing instead of the whole fuel system)
Apr 21, 2010 | 2004 kawasaki Z 750
I have a is1200 pa amp that has a static type sound from 1 chanel, swaping all leads and imputs makes no difference... any ideas????
get a can of freeze spray from an electronics supplier.spray the transistors and chips. if the noise goes away,that is the bad component.the other thing to check is the volume and control pots.spraying them with nutrol or similar will remove noise.
Dec 05, 2009 | Audio Players & Recorders
Timing belt confusion
take timing belt cover off and check for binding possibley belt tention set to tight...
Jun 01, 2009 | 1990 Toyota Pickup
No dash lights
possibly. i would get the wiring checked out by an electrician.
hope this helps.
Mar 18, 2009 | 2000 Volkswagen Passat 4Motion
Perfect picture but the sound is just static!
There is either a tuner problem or trouble in the set's sound processing. When you send audio in through the rear panel jacks, you bypass the circuitry that extracts the sound from a broadcast signal. It's impossible to suggest a place to start looking for you to try repairing it on your own. Depending on how large a set this is and its age, you might try calling for service and get an estimate, or use this as an excuse to replace the TV.
Dec 12, 2008 | Televison & Video
Technics SL-1200MK2 Turntable Logo
337 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
