Question about Breville Die Cast 800ESXL Espresso Machine
Water flows fine until we put in the Filter Holder
Our Breville is pumpming water & steam fine, but as soon as we put the Filter handle in, it makes the pumping noises, but nothing comes out. Does anyone have an answer on how to fix this problem?
    President:
  • 1,618 Answers
The grind on the coffee is too fine, try packing it lighter or setting the grind coarser.
Posted on Jun 30, 2009
    New Friend:
  • 4 Answers
Your filter is blocked. It can be one of two things.
1. Coffee - this is obvious
2. Calcium - if you have hard water (i.e. your hot water kettle has white stuff in the bottom attached to the element)
The sure fire solution is to address both and the procedure is easy.
Since the filter is stainless steel, it can take the high temperatures of a stove top. Put the filter directly on the element and set to high for 10 minutes. This will burn off any coffee clogging the filter. After that, mix equal parts of water and vinegar in a pot, put the filter in and boil at max for 15 minutes.
This should do the trick. If it works for you, please click "yes" on "this is helpful", otherwise click "no". I searched for over a year to understand that my issue was a combination of two things so nothing worked for me. Clicking on yes/no would help the community understand if there are other unknown issues.
Posted on May 04, 2014
The filter is most likely clogged... I've heard people putting it in vinegar for 48hrs with some success. Replacement was around 10$ when I asked the store.
They told me this to make it last better:
-Always flush it by doing a pass with no coffee before shutting down the machine.
-Use coffe a bit on the coarse side for expresso. Powder will clog it otherwise.
Posted on Jan 25, 2010
I'm having the same problem, did you ever find a solution?
Posted on Jan 04, 2010
Fracino little gem coffe machine manual
visacrem intternational limited
FRACINO COFFEE MACHINES
THE LITTLE GEM
INSTALLATION INSTRUCTIONS
.REMOVE PLASTIC BUNG & FILL TOP TANK WITH COLD WATER TO TOP (N.B WATER SHOULD BE SOFTENED)
.PLUG MACHINE IN & SWITCH ON AT MAINS
.TURN MACHINE ON (ON/OFF SWITCH ON SILER PANEL JUST UNDER FRONT RED PANEL- NEXT TO GROUP)
.RED NEON AND AMBER NEON LIGHTS WILL ILLUMINATE AND THE MACHINE WILL START TO FILL
.OPEN STEAM VALVE (TURN RIGHT HAND BLACK HANDLE ANTI CLOCKWISE)
.WHEN WATER LEVEL REACHES THE YELLOW LINE ON THE SIGHT GLASS THE LIGHT WILL GO OFF AND
THE MACHINE WILL CUT OUT
REFIL THE TANK AND THEN TURN THE ON/OFF SWITCH OFF AND WAIT 5 SECONDS TURN THE ON/OFF
SWITCH BACK ON THE MACHINE WILL CONTINUE TO FILL
.WHEN THE WATER LEVEL REACHES THE TOP RED LINE ON THE SIGHT GLASS THE RED LIGHT WILL
GO OUT THE AMBER LIGHT WILL REMAIN ON UNTIL THE WATER REACHES THE CORRECT LEVEL AND THEN
GO OUT
.THE MACHINE WILL NOW START TO HEAT THE WATER WAIT FOR STEAM TO COME OUT OF THE STEAM TUBE
(BETWEEN 5-10 MINS APPROX) AND CLOSE THE STEAM VALVE (TURN RIGHT HAND BLACK HANDLE CLOKWISE)
.WAIT FOR THE PRESSURE TO COME UP TO 1-2KG/CM3 (PRESSURE GAUGE ON FRONT OF MACHINE BETWEEN
THE TWO BLACK HANDLES)
.THE MACHINE IS NOE READY TO USE
.PUT EMPTY FILTER HOLDER INTO THE GROUP AND FLUSH WITH WATER BY TURNING ON RED SWITCH NEXT
TO PRESSURE GAUGE AND LETTING WATER RUN THROUGH THIS PROCESS WILL TAKE SOME TIME AND USE
APPROXIMATELY HALF PINT OF WATER THE GROUP AND FILTER HOLDER SHOULD BE HOT - CHECK BY
TOUCH IF THEY ARE NOT HOT LET WATER CONTINUE TO FLUSH THROUGH UNTIL THEY ARE AND THEN
TURN RED SWITCH OFF
.MAKE A TEST CUP OF COFFEE THIS FIRST CUP WILL PROBABLY BE COLD BUT AS YOU MAKE MORE CUPS
OF COFFEE THEY WILL GET HOTTER IF POSSIBLE LEAVE THE MACHINE TO STAND FOR APPROX 30 MINS
BEFORE MAKING COFFEE THIS WILL ENABLE IT TO WARM UP AND PRODUCE COFFEE AT THE CORRECT
TEMPRATURE.
HOPE THIS IS WHAT YOU WERE LOOKING FOR ITS WHAT THEY GAVE ME WHEN I GO MINE FROM THEM.
IF NOT HERES A LINK TO THE PARTS MANUAL AND CATALOG
http://www.fracino.com/technical/parts.html
http://www.fracino.com/machines/hand-fill-coffee-machines/little-gem.html
http://www.vendingexpress.co.uk/uploads/pdf/product-fracino-little-gem-automatic_4e7a1df44be5d.pdf
Jan 20, 2012 | Coffee Makers & Espresso Machines
Hi, We have just bought a DeLonghi Caffe Treviso. We are not able to get any coffee/liquid to drip out of the filter holder. The problem seems to occur when we are trying to preheat the machine, for...
Sounds like you need to prime the water pump. Remove the filter holder, open the steam knob and then press the coffee delivery switch. Wait for water to flow consistently from the steamer and then close the steam knob. Water should then be forced to flow through the goup head (coffee head). If you cannot get water to flow from steamer then the pump may have already been damaged or it may have been faulty from the start. If water will flow through steamer but not for the coffee, then the group head is blocked. Good luck hope this helps and remember that all machines should be primed like this before use.
Dec 15, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Coffee machine blocked
it could be grind stuck in the (yes the, as in the only) hole in the filter cup. remove the filter cup from the cup holder (the thing with the black handle) and use the tiny pin in the little brown tool to push out whatever is in there. you may have used to fine a grind or stuffed the filter cup too much. careful, that is how you break the plastic filter holder ring.
for calcifying, i just use plain white vinegar. i put it in straight into the clear water holder, about 3/4 cup, then i run it throuhg a bit, let it sit 5 min, run it through a bit, let it sit 30 min to an hour. depending on the day, i repeat a few times, rinse with clean water. i do this about every 2 months.
Aug 03, 2010 | Breville ESP8XL Espresso Machine
Exploding........
Hi All. I too was having this so called exploding issue with my machine & couldn't get any coffee!! The culprit is a clogged filter!! As you might know, Breville uses a double wall construction for the filter which incorporates an inner cup with many fine holes and there is only ONE small hole on the bottom of the outer wall(bottom). I guess over time some fine fine grounds get thru the inner layer and accumulate between the two layers and eventually get compacted enough to completely clog the filter to a point that the pump cannot push the water through it!! Thus the pressure from the pump can't escape & is releasd when you try to remove the coffee basket!! You can try to use a small pin inserted in the bottom hole to see if it clears the obstruction. It didn't work for me! I even tried using high pressure air to clear it, again unsuccessful!
THE FIX: Buy a new filter!
P.S. I found my machine to have some build up behind the strainer where the water enters the coffee chamber. To clean and clear, follow these steps: Unplugg the power cord!! Remove the watertank. Remove the filter holder. Turn the machine upside-down, Remove ONE screw in the center of the coffee chamber(It looks like a strainer with several holes). Remove the strainer and wash & clean any build up behind it. Reinstall in reverse order.
Sep 20, 2008 | Breville ESP8XL Espresso Machine
Steam from brew head, but no water
  1. If you take the coffee filter and head it in light, can you see a little hole in the middle? if not, try to clean it else you have to replace it.
  2. Can you brew out water without the filter holder in the machine? If not, loosen the screw in the middle on the machine where the filterholder shall be and take of the filter. Clean the filter and put it on the machine again.
Hope this help you
Jun 10, 2008 | Breville ESP8XL Espresso Machine
No water thru the group head
We were having the same problem and this worked for us, right from an insert that was included with the manual.
1. Fill tank with water
2. Remove the filter holder
3. open the steam tap
4. press the main switch and the coffee switch at the same time
5. close the steam tap as soon as water begins to flow
6. If after 30 sec. no water comes out repeat the operation.
7. when it starts, draw off 4 cups of water
This worked for us after we had about given up,
Jun 07, 2008 | Rancilio Silvia Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
BrevilleUSA.com has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Feb 17, 2008 | Breville Die Cast 800ESXL Espresso Machine
Hot water won't flow into machine
You most likely need to prime the brew head. Follow the instructions in the owner's manual. To prime the brew head, you'll need to put run the machine without coffee until water starts flowing. One water flows, the brew head is primed and the machine is ready for normal use. You'll need to do this every time you run out of water. Regards, Denis
Oct 09, 2007 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
623 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
