Forgetting paswords is the biggest crime these days and the punishment is reinstallation of the firmware. As if that is not enough, you will lose all data on the phone.
Please get the firmware reinstalled. Either do it yourself using the Nokia PCSuite or get it done from Nokia Care.
First of all you should remove the Sim card and then try to switch on the phone. If it does not work then your phone's firmware is corrupted. Try to hard reset the phone by pressing the green, 3, and * key together and switch on the phone. Hold the three keys until the nokia hands are showing. Then your phone will be reset.
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed. It will only reset the phone settings, such as profiles, themes and shortcuts. The default lock code is 12345.
It must because firmware problem. This could be due to partial installation of updates. It would be better to go to your nearest Nokia service center and get it repaired.
hi sir.. please go to tools>setting>phone>setting>factory settings and type the regular passward 12345 or ur security passward . and it will restard .. it work,s don,t forget to fix. bye sir..
