I have a Trane XE 1000 and attempted to replace the thermostat. When I saw that the wiring configuration was set up for a different configuration I put the new thermostat back in the box without trying to wire it. I put the old thermostat back on, wired it just like it was (I took a pic of the config before I removed it) and now I can not get the system to power back on. Is it possible I blew a fuse or tripped a breaker in the process of reinstalling the old thermostat? There was one point where a spark came off of the red wire even though I had all the breakers off. Please help, its over 100 out here and I can't get any A/C techs to come out until Monday
  • 52 Answers
You could test this by totally by passing the stat and connecting through a wire linc.
However you seem a little to inexperienced to be doing this and in my opinion you should for safety sake wait until monday,for a tech.
Posted on Jun 27, 2009
I am looking for a wiring diagram for a Trane XE 1000 2 ton ac unit
Look on the back of the electrical panel after removing it from unit.
Mar 19, 2016 | Heating & Cooling
I have a trane xe 1000 heat pump with aux heat strips, trying to install a carrier tstatccpaco1-b digital termostat, any suggestions on where the wires go? My friend said to just match the wires off the...
All wiring should match up. It should be W-White wire, then it should be G-Green Wire, then C-Blue Wire, then it should be O-B-Orange Wire. Then it should have a Y-Yellow Wire, then a R/RC-Red wire. There should be 6 wires. If Blue wire is not used you will have to use batteries with the new t-stat, if it takes batteries. Blue wire is optional. I hope you find this helpful.
Feb 25, 2018 | Cars & Trucks
Trane xe 1000 - 1/4 fan motor went bad - I replaced it with a used 1/3 from another trane unit - it had same wiring harness etc everything starts, runs, cools -cold air - but only for about 5...
Did the 2 fans have the same rpm. If there is not enough airflow through the outside unit the compressor will shutdown on high discharge pressure. Also make sure the fan blades are positioned right if there is a shroud for them. Did the other motor have a capacitor with it or did you use the 1 from the smaller motor. Sometimes the motor data plate will tell you what size capacitor you need. Let me know what you find.
Aug 24, 2010 | Heating & Cooling
I have a Trane xe 70. The Heat is not turning on. The ignitor will glow but NO gas or blower. I turn on the fan and the blower does work but not when HEAT is selected on the t-stat. Also the LED light...
Check to see if you get 24 volts AC at the gas valve from the circuit board when the igniter is glowing. If yes, bad gas valve or blockage in gas train. If no, bad circuit board or broken wire
Feb 07, 2010 | Heating & Cooling
Trane xe 1200, can i use the heat blower with out a working compressor, i need heat not air, thanks
you can switch the thermostat to "emergency heat" which will turn the outdoor section off and the thermostat will control the electric heat elements in the air handler if it has them.
Oct 19, 2009 | Omega Trane Furnace Draft Inducer Blower ...
I have a Trane Xe-60 furnace about 19 years old. During summer months, with thermostat set to deliver air, the outside condenser runs, but furnace blower does not. I can move thermostat lever from auto to...
THIS IS A COMMON PROBLEM WITH THE DOOR SWITCHES, MY FIRST ANSWER WOULD BE REPLACE THE SWITCH SECOND WOULD BE OPEN THE DOOR AND PUSH THE BUTTON IN AND SEE IF THE FURNACE WILL WORK. THIS SWITCH IS JUST A DOOR SAFTEY IF THIS WORKS. I HAVE TAPED A PIECE ON THE INSIDE OF THE DOOR WHERE THE SWITCH WILL HIT THE DOOR ABOUT A 1/4 INCH THICK AND SEE IF THIS WILL GET YOU RUNNING UNTILL YOU CAN GET A SWITCH
Oct 12, 2009 | Omega Trane Furnace Draft Inducer Blower...
Heating & Cooling Logo
560 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
