Question about Kenmore 64823 Top Freezer Refrigerator
Switching sides on the handles,,,
I need to know how to remove the handles to switch sides
  • Anonymous Dec 04, 2007
    remove handles from left side to right side of fridge
  • Anonymous Mar 19, 2014
    I need to remove the handles from ski-doo snowmobile skis
  • 473 Answers
Give me the complete model # off the sticker inside the fridge section and I can help you.
Posted on Nov 07, 2007
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Mar 07, 2011 | 1998 Ford Windstar
I need to know how to get the drivers side door panel off. My window is off track and I need to fix
how to remove door panel on a 97 expedition, pull up on master window switch bezel careful clips break easily and unplug the connectors, remove triangle trim piece top right side of panel pull out then up, screw behind it remove it, remove red lense plastic piece on bottom of door small screw driver careful breaks easily screw behind it remove it, remove bezel around door handle turn it to get off handle screw behnd it remove it, pull straight up on door handle gently then hard if needed, after it is loose from door remove light bulb socket from behind door panel turn it, unplug power window switch.
thats it reverse to put back on
Nov 25, 2010 | 1997 Ford Expedition
How to remove right front panel on 2000 ford
This is for the front passenger side door panel from a 1999 Ford Expedition. The driver's side door should be the same, except for the mirror switch which needs to be unplugged. The 1998 *might* be the same, I don't know, but this should be helpful to someone.
Use a flat blade screwdriver or other suitable tool to pry out on the top of the triangular plastic panel on the top front of the door panel. The plastic holder should pull out of the door. Now pry up on both sides of the triangular panel and pull it loose. Remove the philips head screw you find under this panel. Pull the door latch handle, pry out the insert where the handle goes through, and remove the bolt that holds the door handle in place. Remove the door handle. Pry up on the ends of the door switch panel to remove it. Unplug the cables by pushing in on the lock tab on the side of the plug and pulling out. Remove the philips head screw accessible through the switch panel hole. Insert a flat blade screwdriver into the slot at the bottom of the courtesy light lens and pry up and out to remove the lens. Remove the philips head screw behind this lens. Pull up on the door panel to remove it. Be careful of the courtesy light when removing the panel - give the light a quarter turn counter-clockwise from the rear to remove it from the door panel.
Its possible that this GUIDE can helpfull as reference.
Hope this help.
Apr 22, 2010 | 2000 Ford Expedition
I have an Aerus Guardian canister vacuum with a clogged hose. The tiny stuffed animal toy is lodged right below where the swivel handle meets the hose. Switching the air flow does not dislodge it. I would...
Consider this. If your vacuum is still under warranty, removing the hose will void the warranty on the hose. I strongly recommend calling an authorized dealer/consultant.
Although it may seem to be fairly simple to remove the handle, there are wires that need to be disconnected in order to separate the handle from the hose, gaining access to the toy. And reconnected. If not properly done, attempting this may lead to needing to purchase a new hose.
Apr 19, 2010 | Electrolux Guardian Bagged Canister Vacuum
Driver's side window switch doesn't work.The switch that lowers and raises the driver's side window in my 1998 Toyota Avalon has stopped working. Until last week, it worked sporadically. I think the switch...
i know on some toyotas, you do not need to remove the door panel just the handle where the switch assembly is located...if the panel around the switches is plastic then pry GENTLY up on the plastic to dislodge it from the door handle and inspect connections there...if everything checks out fine, then check fuses...perhaps this was a problem for so long that the window motor finally blew a fuse. if so replace both fuse and motor...if fuses okay, then with a long screw driver locate any screws under the door handle, bottom of the door panel, mirror panel etc, and remove...then gently pry outwards on door panel until it is released. disconnect your harness at the window motor and hook in a test light and operate the switch..if light illuminates, replace motor..if not, then replace switch or switch panel..which ever/.
Nov 13, 2009 | 1998 Toyota Avalon
Door and Boot Locks
the problem lies in the drivers side operating switch for the central locking .this would involve removing the drivers side door handle and checking the switch mechanism thats built into the lock,havent done one o n this model only a opel astra ---but they are different from the opel although the car looks the same ,well similar pull it off have a go ,the key barrel must turn something so look for an internal switching or external switching and see if the spring is ok that returns the switch
May 02, 2009 | 2001 Daewoo Lanos
On-off switch is stuck on
on the back of the handle down below the grip you will see 4 screws take them out.then slide the handle out towards the back.on the sides of the handle you will see small notches those are the snaps the hold it together.the handle will come apart.feel free to call me if you need help i don't charge just like to help people save money.if there is a cord cradle there you may have to take that off also,held onby 2 screws.314-628-9153
Apr 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Check two things with this model: if the top slider button has been activated it will turn the brush roll on. If not then you'll have to remove the sole plate and check the sides of the beater bar - sometimes this will get jammed and refuse to turn because clogging of dust or tangled hair/carpet thread takes up the thread wheels at the sides. Sadly this model has a permanent toothed drive belt that can't really be replaced by the owner. However check the slider control on the top of the main body / handle first before doing anything - as you know it has a two option slider - switching on without the brush roll function and switching on with the brush roll activated.
Feb 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Switching doors to open the opposite direction
Look on the other side of the door and see if there's a plug covering a hole even with where the door handle attaches on the opposite side. If so, I think you just unscrew the handle from the top of the fridge door or bottom of the freezer door an unhook the other end and reattach on the other side of the door. And unscrew and move the hinge to the opposite side. If your doors can be reversed the holes should arleady be in place. It didn't look overly difficult when the delivery guy changed mine when the fridge was delivered.
Nov 24, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore 64823 Top Freezer Refrigerator Logo
69 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
