Question edited for clarity. So few words, so many mistakes. It looks like the year is wrong for a Prowler XT and Error Codes have 4 digits not 3.
Question moved to model category.
? 9:58
https://www.youtube.com/watch?v=iwwl4LPyOCY
Dec 29, 2009 - Uploaded by BlaineDP
When in the "OFF" position the switch will ground the ignition wireto the chassis effectively "grounding out" the ignition systemkilling the spark. ... becomes disconnected or if a wire gets cut then the switch will no longer turn off the engine. ... Testing a stator in a snowmobile Arctic cat - Duration: 3:25.
If the connection to any switch; key, kill, tether, throttle safety switch, etc.. is ... Some older model Arctic Cats have the ground up closer to the handle bars on ... Here is a general rule of thumb for putting spark plug wires on which cylinder for Cats: ... Pulledthe ECU cover off and found some corrosion; I had a 580 that did not ...
Engine Coolant Temperature Circuit Intermittent
Our emissions expert has put together the following information about the P0119 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code. OBD II Fault Code
OBD II P0119
Fault Code Definition
What does Mean?The Engine Coolant Temperature Sensor measures the rise and fall of the Engine Coolant Temperature. This provides critical data needed for the Powertrain Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing, the cooling fans, and many components of the Emissions Control Systems. The Engine Coolant Temperature Sensor converts the coolant temperature into a voltage that is high when the engine is cold and low as the engine warms up.
Code P0119 indicates an intermittent voltage input from the Coolant Temperature Circuit to the PCM.
The problem I've seen with this code is with the timing sensor. The wires that go into the sensor aren't sealed. Oil gets in there and it shorts out causing the codes P0336, P0337 and P0339 to show up on the dash. All are timing sensor codes.
Nothing to do but go to the dealer and get another stator/timing sensor installed. Heard that they have all been updated and sealed proper-like so it shouldn't happen again
