How to use gas hot water heater in Rockwood Ultra Lite travel Tra
How to use gas hot water heater.
We have bought use ultra light rockwood, has a gas hot water heater
Ultra Lite Travel Trailer ( no. 2502 ) year 1999
Need to know process of use, do we flush.
Fill with water
Any safety on lighting pilot and how.
Other words anything you know on GAS HOT WATER HEATER.
We do not want to blow up camp site.
Thanks Jon Creswell
Master_Tech
  • 770 Answers
SOURCE: i have a whirlpool natural
is it a standing pilot? or Spark ing. model? if standing pilot you will need to replace the Thermocouple if spark you will need to replace the spark box
Posted on May 11, 2008
SOURCE: Air conditioner leaks/drips from filter inside travel trailer
Either your 14"x14" a/c gasket is lose on the roof allowing the condensation to flow into your RV or you have a cracked condensation tray under the evaporator. I'm guessing the later
JGRV
Posted on Aug 14, 2008
  • 35 Answers
SOURCE: gas hot water tank, pilot light
Look inside the water heater when it is heating the water, the flame should be blue. If it has yellow tips on the flame, it needs an adjustment to the air shutter. There is a nut on this air shutter to make this adjustment. This adjusts the air gas mixture. You may first try just simply tapping on the burner lightly to loosen any debris that may have built up and vacuum it out. MAKE SURE YOU TURN OFF THE GAS BEFORE CLEANING THE BURNER!! Also, check for drafts that may be blowing out your pilot light, Furnace register or outside drafts on windy nights. Some water heaters have an automatic shut down if the water heater gets too hot, so don't have it set to its hottest setting. Most water heaters only last about 10 years or so, It could be you are ready for a new one....Joe
Posted on Dec 16, 2008
SOURCE: gas water heater kenmore model pilot will not stay lite
I have the same problem. Water heater operates on a very simple principle. of thermo-mechanical feed-back and response. In my case, I have a Kenmore Power Miser 6, NG heater with an electronic pilot ignition system. The heater is just over one year old and last month (conveniently just after the 12 month service warranty expired) the pilot light started extinguishing on a very regular basis. I find it interesting that the very problem I am experiencing, is happening to other Kenmore owners (victims). The solution can be found in replacing one of two possible components; the pilot assembly or the gas valve manifold. The price of DIY pilot assembly replacement is approx. $60 . The valve component is significantly higher. Water heaters are designed and built to provide years of trouble-free reliable service. This is the first Kenmore product I have owned. From a customer perspective, with regard to product performance, Sears/Kenmore needs to take a strong look at their supplier quality. Oh, by the way, contacting Sears for remedial relief only managed to frustrate and infuriate me. You see, I am in Quality for a world-class aircraft company. I understand what ethical steps are required to satisfy a valued customer. I plan on ripping out the defective unit this weekend and replacing it with a reliable Home depot special. At least with HD, if the heater fails to perform , I can return it. Hey Sears in Chicago, don't come crying to the consumer when you are looking for the trendy "bail out". Signed- "Burned Out" in La Habra, California.
Posted on Apr 10, 2009
  • 297 Answers
SOURCE: I have a 6 gal Atwood hot water heater. I can
Kenny did you change the thermo coupler?
Posted on Jul 14, 2009
I need to winteriz rockwood signature ultra lite 8310ss
find heater bypass close off heater then blow out with air through city water inlet then find water pump take off inlet and add antifreeze through pump after all faucets and toilet have red add antifreeze to traps then return heater to operation
Oct 10, 2017 | RVs
Would like to get an owners manual for a 2010 Rockwood Ultra lite, where can I find this?
Forest River (Rockwood is a model of theirs) only lists manuals for the past 3 years. You'd be better served and more informed if you write down make and model of every component you find in your RV. Then use Google to search for manuals for each system. These will include operating instructions, troubleshooting, and often parts. More valuable than the RV owner's manual.
Apr 26, 2017 | RVs
2012 Rockwood 8288ws just purchased. When I turn the switch on for the water heater it cycles trying to ignite gas. I want to run electric only. What am I doing wrong?
1st Question - Can you verify that you actually have a Gas/Electic Waterheater? Most units are gas only. You may have to look at the unit and look for power cables.
2nd. Is power connected prior to turning on the water heater?
May 10, 2015 | Forest River 2012 Rockwood Signature Ultra...
How to turn on water heater
This might not be much help, without more details, but there should be a valve inside the water heater panel (outside) you can open. Open the valve at the main propane tank also.
Make sure the water tank is FULL before you fire it up. There should be a switch inside the coach somewhere to turn it on.
If it doesn't ignite immediately, you probably have air in the lines. Light the stove and let it burn for a minute, then try the hot water tank again. Might take a few tries to get it fired up.
Apr 28, 2015 | Forest River 2011 Rockwood Signature Ultra...
Rockwood travel trailer 2009 ultra lite 8292BDS
I would be contacting the manufacturer on this one because if it is a defect in manufacturing or in design they should be able to help you out . There should be spares available and I would recommend a new item rather than trying to repair it
Apr 27, 2014 | Cars & Trucks
Lost keys to my Forest River 2013 Rockwood Ultra Lite 2703WS whats the easyest way to get in?
You may be able to climb in through the front storage compartment and raise the bed. Or, some mobile RV repair techs have a master set of keys and can let you in for a nominal fee. If you happen to know what the key number is then you can purchase a replacement key. FIC and Global keys each have 51 different cuts of keys. FIC will have a key code of HF or CF 3** and Global will have G3**.
Apr 06, 2014 | Forest River 2013 Rockwood Ultra Lite...
Rockwood trailer manual
Contact the manufacturer of the coach for their owner's manual. However, each appliance will have a separate owner's manual form its perspective manufacturer, i.e., Water Heater = Suburban, A/C = Dometic, Refrigerator = Norcold, etc.. There will not be a diagram of electrical or plumbing as a majority of the RV manufacturers do not publish that information. The only thing that I can think of that would cause the TV to reset when the Air Conditioner comes on is if the AC is remote controlled you may have a frequency conflict. It is not typical for the AC to share an electrical circuit with the TV but if that is the case here then the TV may be getting shut down because the AC is drawing too many amps on startup for the TV to continue to function. Turn the breaker off to the AC and see if the TV shuts down also. If it does then you will need to get the issue corrected.
Apr 02, 2014 | Forest River 2011 Rockwood Signature Ultra...
Rockwood camper manuel
Forest River appears to be the manufacturer so try them first for information
Jul 19, 2013 | Forest River 2011 Rockwood Ultra Lite...
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
