Question about Orion Televison & Video
When i hook my dvd player to my tv the picture scrolls and is jumbled
  • 100 Answers
Dvd pl.in progr.scan mode.
Posted on Jun 27, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Why is picture scrambled on my memorex dvd mvd2016
The MVD is a progressive scan DVD player if your TV is 1080i or shows interlaced images only and doesnt have the option for progressive scan this would be an issue. I would suggest trying this DVD player on another television first. Also what is the model of your television?
Another issue is if you have and HD TV and are hooking up the A/V jacks to the HD component inputs this would also provide a jumbled picture. It would be a good idea to check and make sure that the A/V cabled are inserted into the correct input.
May 05, 2011 | Memorex MVD2016 DVD Player
Hook up to dvd player
There are more than two methods of hooking up the DVD player.
1) Get a 5pin component cable with Red, Green & Blue pins. Connect the DVD Player's RGB out pins to the TV's RGB in socket. This will take care of the picture. Then for sound you will need the secondbobhifi_4.jpg set of Red & White cable. Connect the Red & White pins to the DVD players audio out socket (Red for right channel and White for Left channel ). The other end of the cable you can connect to the Red & White socket next to the RGB socket where you have connected the Video. Play a DVD and scroll through the inputs slowly. You will see the picture appear on one of your selections.
Mar 10, 2011 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Just moved, hooked up DVD player to new TV. Sound
if you have a picture on the tv from normal channels and/or cable, then i would suspect the scart lead may have a bent pin at one end or both or is not inserted fully.
Feb 20, 2010 | GPX D1816 DVD Player
Hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
Jan 21, 2010 | TruTech PM1919BXA1 19 in. LCD TV
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
No picture from Home Theater/ DVD player... only sound
Have you checked to see if your t.v remote has an input selection button ? If it does than just scroll through the inputs and see if this works.
Jan 31, 2009 | Audio Players & Recorders
DVD Player is not tracking the picture
DVD players are dirt cheap now. Just buy a new one, and if your TV has HDMI, get one that will hook up that way.
Aug 06, 2017 | Lasonic DVD-8090 Portable DVD Player...
Hooking dvd player to tv
check if your dvd video output is switched to the svideo or RGB and make sure it is switched to the output youare connecting video cable .
Dec 31, 2007 | Philips 32PT6441/37 32" TV
NEW DVD PLAYER, PHILLIPS DVP3120 PICTURE SCROLLING RIGHT TO LEFT
have you tried the scarts they are fully inseted to dvd and also the tv , some times the cables become loose this can cuase this to happen .
riz.
Nov 20, 2007 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
