Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
Scotsman CM250AE Ice Machine tech help
Good Day,
I am servicing an older ice machine. It had a seized water pump which I have changed out as well as the water solenoid. When the ice starts to form on the plate the unit seems to go into harvest mode earlier than it should and we get very small cubes. The water solenoid starts to fill the reservoir and fills it to the overflow and beyond. The unit starts to freeze the plate after about four-five minutes of operation.
  • 1 more comment
  • Anonymous Mar 17, 2014
    sce170 will not harvest, water runs down curtain, does not freeze, in manual mode the evaporator runs but no ice is formed
    sce170 will not harvest, water runs down curtain but will not form ice, in manual mode evaporator runs but ice is not formed
  • Anonymous Mar 18, 2014
    water keeps running over evaporator but never freezes, in manual harvest mode evaporator chills but no ice is formed
  • 102 Answers
You have a timer issuse it may just need to be adjusted or relpaced
Posted on Apr 24, 2014
    New Friend:
Cube size thermostat is stuck closed which keeps the timer motor running all the time, thus short freeze cycle.
Replace the cube size thermostat.
Posted on May 22, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
Adjust harvest freeze timer so the water just fills resevoir then adjust ice thickness control
Posted on Apr 20, 2012
Water keeps runing out of drain & makes vary little wet ice
Posted on Apr 19, 2011
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Posted on Nov 07, 2007
Scotsman cm250ae-1c making very wet ice
It might be a dirty or damaged ice tray. When in the harvest mode the hot gas will be directed through the tray untill the cubes fall tripping the reset to start the freezing cycle again. If the cubes are sticking because of rust or scale buildup the cubes get "overmelted" causing the "wet cubes".CAREFULLY clean the ice tray . Use vinegar or ice machine cleaner do not use any cleaning pads steel wool or sand paper as this will ruin ice tray. Also make sure icemaker is level both ways. Hope this helps.
Dec 27, 2013 | Refrigerators
I have a SCOTSMAN ICE MAKER MODEL NUMBER CM250AE-1E and the water coming into the machine never stops. It fills the tray until the water runs out the drain in the back of the machine.
I ran a service call on this model today with the same exact problem. I diagnosed it with a bad fill valve. The valve is not closing all the way and therefore lets water in all the time. With yours, the problem could be a bad timer or a bad microswitch or a bad valve. Hard to tell without looking.
Now to find the replacement valve for this thing...
Oct 02, 2012 | Scotsman Ice Maker With Bin Cube Style...
Why does my scotsman ice machine, model cm250ae-1e, freeze over on ice cube grid?
check ice thickness thermistor if its not working properly timer will never start advancing
Jan 19, 2011 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
1,120 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
