Question about Microwave Ovens
I have a KitchenAid KHMS145kss, over-range microwave hood combination. Is there any easy way to check if it is installed as non-venting/recirculating or vented? We have an external vent, but i am not sure if teh unit is hooked up to it. The integral vent does blow (back into teh kicthen) when the fan is on.
  • gary131 Jun 28, 2009
    Now that the microwave is already installed, is there a way to knwo whether it was installed in venting or non-venting mode, short of uninstalling and reinstalling the microwave?
    That was a great answer, and very helpful. Thanks very much....
  • 15,935 Answers
If the venting is to the outside - the air will not come back and recirculate at all.
When you install the microwave - you actually MUST remove the fan assembly and rotate it - essentially blanking off the interior vent.
To check for SURE - simply drop the microwave. It is held in place with 2 bolts in the top cabinet.
Take 1 bolt all the way out... then re - install it 3-4 turns.
Then back out the other one until the front of the microwave tilts down far enough to see the vent at the back.
If you see a hole there - the venting is to the outside.
If there is a silver metal cover - the venting is inside.
SEE THIS DIAGRAM - #18 is the blanking plate of your unit.
One less intrusive way to check the vent while cooking. Go outside and feel for heat, air flow, or moisure while heating or venting from the stove.
Thanks for using FixYa - please remember to rate this answer FixYa so credit is properly distributed... or it goes back to the 1st "Expert's" answer by default after 7 days
Posted on Jun 28, 2009
  • 583 Answers
The link below will explain the installation mode and help you determine the mode of installation as it has all three installation mode procedures on it.check from page-4.of the manual on this link.
http://www.dvorsons.com/Frigidaire/Ovens/ORMICRO316137233.pdf
thanksfor using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 27, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Min distance from gas cooktop
First, read the service manual. Contact the seller, or read the FAQs on the KitchenAid website.
Jun 25, 2014 | KitchenAid KHMS145KSS Microwave Oven
Microwave makes loud sound when running.
You don't. If it's doing that, there's something wrong with it. It needs to be replaced.
Apr 29, 2014 | KitchenAid KHMS145KSS Microwave Oven
Samsung microwave internal vent cover melted
The temperature reached a high enough value to make the plastic melt .The device ran for too long. The device ran without any substance (food) to heat.
Nov 26, 2013 | KitchenAid KHMS145KSS Microwave Oven
Khms155lss-3
You need to order the part from KichenAid, or visit a appliance dealer/repairman.
Mar 18, 2012 | KitchenAid KHMS145KSS Microwave Oven
Looking to replace the plastic piece on the vertical edge of the door (handle side) on my Kitchenaid Microwave/Hood combo khms145kss1. Is it possible to just replace this instead of purchasing the entire...
They don't show the entire door assembly as being available.
But you can replace the outer door frame (outer door panel)part number 8184319.
At $167.94, it's not cheap. But you can get it here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 29, 2009 | KitchenAid KHMS145KSS Microwave Oven
Internal venting of KitchenAid Microwave oven hood combination
That info is in your installation instructions, which can be found here.
Jan 03, 2009 | KitchenAid KHMS105E Microwave Oven
Kitchenaide Microwave KHMS145KSS rattling noise
there is a possibility that sme of the wireing or the fan has become loose best checking it .
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
