I have a dell photo 926 all in one printer. The paper was only feeding part of the way and then getting stuck. I was advise by technical support to feed an envelope thru the printer to see if any paper was stuck in the printer. the envelope is now stuck in the printer and was told the printer is worn out, discard and buy a new one. I hung up. I am attempting to take the printer apart to get the envelope and paper out.
SOURCE: Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
SOURCE: envelope stuck inside of printer
Raise the scanner lid as if you were going to change the ink cartridge. You should be able to see the stuck envelope -- just grasp it and pull firmly to remove it.
For suggestions on avoiding paper jams, please go to Dell's support page.
Please rate this solution if you find it helpful!
~~Cheryl
SOURCE: Dell Photo 926 printer no longer feeds paper correctly
Normal
0
Could have a corrupt driver.
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: new dell printer 926 does not feed paper need repair manual
is it under warrenty? contact the vender if it is as you may void the warrenty if you try to fix it yourself
SOURCE: I have 2 Dell model 1700n laser printers and they
Take off the two rubber rollers, turn them inside out and replace them, Voila!
