Question about Acer Aspire 5101WLMi Notebook
Keyboard and touchpad iffy!
I had a friend bring me a Acer Aspire 1640 laptop that was having problems with the touchpad working "jerkily" and the Keyboard getting slow or not working at all. I found that if I took the battery out and just had the AC cord plugged the problems went away! We're ordering a new battery and in the mean time she can use the laptop with just the power cord (and battery removed).
I have an Acer aspire 1640, the screen remains blank
Try to connect the laptop using and external monitor if the external worked the problem is with the laptop. If not try to reseat the memory module also.
ERNZ
Feb 03, 2010 | Acer Aspire 1640Z Notebook
Acer Aspire 4930G Keyboard touchpad not responding? Cursor responds with external mouse, keyboard responds in dos mode. keyboard and touchpad are not present in device manager, system restore is useless in...
in my opinion. your touchpad driver is defected by virouse /re install once time it, second your computer touch pad hardwere is damage,check it using by another keyboard and mouse. then u can get result --thanks
Jun 13, 2009 | Acer Aspire 5101WLMi Notebook
Touchpad or keyboard not working
Press and hold the blue function (Fn) button and F7. This turns the touchpad on and off.
Apr 13, 2009 | Acer Aspire 4530-5889 Notebook PC
Touchpad & Keyboard unresponsive
please replaced the laptop ,other option u r put the button & clean the button
Mar 16, 2009 | Acer Aspire 5720 Notebook
Acer 3500 mouse touchpad totally frozen
have you tried updating the driver
or go to control panel and mouse and check the settings in there
does your laptop work with a normal mouse
Nov 19, 2008 | Acer Aspire 3100-1405 Notebook
My keyboard and touchpad is not working..
attach a usb keyboard to the laptop, then check
Nov 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Keyboard,sound,touchpad all not working keyboard, touchpad and all usb ports stopped working
kINDLY CONNECT A USB KEYBOARD AND/OR MOUSE TO TROUBLESHOOT THE NOTE BOOK IF USB KEYBOARD/ MOUSE (EXTERNAL NORMAL USB DESKTOP KEYBOARD MOUSE). THEN WE WILL BE ABLE TO TROUBLE SHOOT
Feb 29, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3004 keyboard and touchpad error
Just resolved same problem on Acer Aspire 5000 by removing the battery, then goto device manager and disable "Microsoft ACPI-Compliant Control Method Battery" you can then put your existing battery back into the latop with any problems with the keyboard and touchpad. Mad solution I know but it worked for me
Jan 22, 2008 | Acer Aspire 3000 Notebook
Acer 1640
  • shutdown and power off your acer laptop
  • then remove the battery out of laptop
  • connect the power and switch on ur laptop
  • let it boot to operating system
  • check if its working now? ur keyboard and mouse should be working now
  • you can now connect the battery and keep working.
  • if u want to power off, put ur laptop in hibernate more, rather than shut-down. so u dont have to reboot next time without battery.
  • if u restart or start ur laptop after a shutdown, make sure to remove the battery first
    i hope this will help.
more details can be found on the cnet forum @ http://forums.cnet.com/5208-6620_102-0.html?forumID=44&threadID=294657
Jan 03, 2008 | Acer Aspire 1642WLMi Notebook
Keyboard/touchpad freezes when the battery is plugged!!
I SOLVE THIS ISSUE 100% WORKING
THE MAIN PROBLEM IS ON THE CONTACT BETWEEN THE BATTERY WIRES AND LAPTOP
IF YOU MOVE THE BATTERY IT WILL WORK SO SURE THE PROBLEM WITH THE LINK BETWEEN THE BATTERY AND THE LAPTOP
SOLUTION : TO MOVE THE IRON OUT OF THE LAPTOP TO THE RIGHT TILT THEM TO RIGHT SIDE A LITTLE BECAUSE THE BATTERY WIRES IS TO THE RIGHT SIDE (WATCH THEM) NOT IN THE MIDDLE AND AFTER THAT PUT A STICK ON THE BATTERY TIGHTED IN ITS PLACE SO IT WILL NOT MOVE ITS NOT FREEZING NOW THANKS
Dec 21, 2007 | Acer Aspire 5100 Notebook
Open Questions:
Acer Aspire 5101WLMi Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
