Question about Cars & Co X Pattern Off Road Tires 1/8 Scale
Tires scraping my outer rim on the driver rear side !!!
I have 2005 mazda6 s model it did not come with facory wheels or tires the wheel i have is kumho tires asx model 215/50R17and konig wheel 7.5x18 . when their is a dip on the road the tire scrapes the rim of the car plz help it also happens everytime their are 4 people sitting in the car do ichange the rim i checked my struts nothing is wrong with it plz help me
email me siddu24usa@yahoo.com
  • Sean Bailey May 11, 2010
    You state that your tire size is 215/50R17and your wheel size is 18. Please clarify, are they 17 or 18's.
  • 114 Answers
You have the correct tire size; however 17" tires are impossible to mount on 18" wheels...so ?? Assuming your tires are on 17" wheels & your struts are good then the next step is to check ride height & replace springs if the height is to low.
Posted on Sep 14, 2009
  • 55 Answers
The problem is that your car is sitting to low you will need to go to a machanic to get a lift kit for your car so that it will stop rubing against the rim or get smaller tires and it will work just as well
hope this helps you
Posted on Jul 30, 2009
What rims enterchange with a 2005 kia amanti
Kia Amanti Rims & Custom Wheels - CARiD.com
www.carid.com > all products > wheels & tires > custom wheels > Kia
Set your Kia Amanti on the finest chrome rims. Our inventory is the top-notch selection of custom wheels and tires for Kia Amanti from most popular wheel ...
Kia Amanti - Wheel-Size.com
www.wheel-size.com > Makes > Kia
Kia Amanti - Find out the correct alloy wheel fitment, PCD, offset and such specs as bolt pattern, thread size(THD), center bore(CB) for all model years of Kia Amanti. Choose a model year to ... 2009 2008 2007 2006 2005 2004 · Kia Amanti l ... Wheel General Info The ranges of possible values for tires and rims of Kia Amanti ...
Buy Wheels and Rims Online for your 2005 KIA AMANTI ...
www.performanceplustire.com > Wheels > KIA > AMANTI
Buy Wheels and Rims Online for your 2005 KIA AMANTI and other custom wheels andrims from PerformancePlusTire.com. PerformancePlusTire.com is one of ..
Oct 25, 2015 | Kia Cars & Trucks
Why does my the rear end of my car shake at highway speeds?
have the rear suspension bushes checked out including the shockies.
I would also suggest a rear end wheel alignment and a wheel bearing check
Jun 19, 2015 | 2006 Hyundai Sonata
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
Burning plastic smell from drivers side rear wheel
pull off wheel and check brake pads low,caliper sticking ,or debris -if brakes look good than check hub-wheel bearing----- may be going bad
Apr 11, 2014 | 2005 Honda Accord
I have a 1977 Dodge. Model # M500, removing inner dually tire
THE INNER STUDS FOR THE INNER WHEELS ARE NUTS AS WELL AND SECURE THE INNER WHEEL. USE A SQUARE DRIVE TO REMOVE THESE STUD/NUTS. DRIVER SIDE NUTS/STUD ARE LEFT HANDED(STAMPED WITH A BIG (L)). AND PASS SIDE RIGHT HANDED. THESE TORQUE SPEC OUT @ 400-450 LB FT. OF TORQUE, YOU WILL HAVE TO USE A CHEATER BAR OR HEAVY DUTY INPACT!
Apr 26, 2010 | 1983 Dodge Pickup
Took wheels off and now 3 of them rub against the shock the front drivers side and both rear.
same wheels, if so then rim is not properly mounted remove one at a time, you may have to clean were rim mounts on to hub,the rim should slide on easy, you should not have to tighten lug nut to get the wheel to sit all the way back if thats the case then cleaning of center of rim and hub is needed, good luck.
Oct 31, 2009 | 2004 Pontiac Grand Am
Tire sizes 1994 toyota corola
Tire Fitament:
Front and Rear Tires
Tire Size:
P185/65R14
Wheel/Rim Size:
14x5.5 inches
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 10, 2009 | 1994 Toyota Corolla
Wheel alignment
you might have bent the rim.
Nov 28, 2008 | 2005 Volkswagen Jetta
Cars & Co X Pattern Off Road Tires 1/8 Scale Logo
197 people viewed this question
Top Cars & Co Toys Experts
Tom Chichester
Jim Snideman
Jim Snideman
Level 1 Expert
Are you a Cars & Co Toy Expert? Answer questions, earn points and help others
