Question about Sega Dreamcast Console
Sega Dreamcast screw
I disassembled my sega dreamcast, and now when I tighten the screw on the metal disk-reading part (the whole thing) it starts to lift up. What's the problem. It's the disk reading part with two screws that screws it into the console. How can I tighten the last screw without the whole thing lifting up. I can only screw in the screw part of the way before it starts to lift up. Is this normal. How can I screw back in the last screw without the whole thing lifting up. I know it's supposed to lie down when all of the screws are screwed in, but this last screw by the power supply is keep making it lift up. The model number for my sega dreamcast is HKT-3020 please help!
  • Parker Drake Dec 08, 2007
    Still is lifting uo. I push the disk-reading piece in, but it still is lifting up when I screw in the screw by the powersupply. Please help me!
  • 709 Answers
The Disc drive has a connector on the bottom that has to mate up with the opposite gender connector on the top of the motherboard. you have to press the Drive down first then put the screws in.
Posted on Nov 30, 2007
  • Greg Stokes
    Greg Stokes Dec 08, 2007
    There is nothing suppose to pertruding out unerr the Disc drive except for the rectangle shape connector tthat is supposed to hook up with it mate on top of the motherboard, Look undert the Disc Drive box and see if you go something more than is not supposed to be or somethhing on top of the motherboard keeping the Dsic drive box from mating up properly.
I was given a sega dreamcast everything works but when it says install disc i put the disc on the wheel close the door and the cd wont stay on the wheel
If I recall the Sega Dreamcast wheel is a clasp type wheel. You need to push the disk down onto the wheel and you will hear it secure itself onto the wheel. Then close the wheel and you should be good to go. Don't just place it on the wheel... push it down until you here that little clicking sound and it should stay on the wheel.
Aug 10, 2011 | Sega Dreamcast Console
Sega dreamcast not reading metropolis street racing
judging by age i would save your CD must have scratches try some cd scratch fixer if you have any
Jan 16, 2011 | Sega Dreamcast Console
When I install some disks into the machine, instead of loading the disk, I get a screen that says Play,File,Music and Settings and don't know why.... Other of my disk load fine!! Can you help me??
yea it's either the disc is not a disc of the country u are in or the disc may be damaged... also.. u can't install disc onto a sega dreamcast... if' it's backup games that u are playing u will need a boot disc... u can google it.. it's commonly called dreamcast boot disc and the image file is free on the net...
Sep 23, 2010 | Sega Dreamcast Console
Dreamcast turned off when there's a disk in it
madarchod band kar de ......from ayush yadav lps lko
Apr 08, 2008 | Sega Dreamcast Console
Won't read disk
Certain Sega Dreamcast Consoles have issues with the laser lens and the motor of the disk reading system. Some of them die after a certain period of use.
Apr 03, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Dreamcast Loading problem
you can get disks relayered at game stores.
there was a long period where this happened to me.
some games worked for a while, some didnt.
its the dreamcast.
you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
try playing with the console upside down
it sounds crazy but it worked for me.
Dec 18, 2007 | Sega Dreamcast Console
Sega Dreamcast Disk-reading piece
cripes I think you may have mixed your screws up?
1 it sounds like you are using a self tapping screw (it has a greater distance between each layer) rather than the tight screws which are for fitting the circuits together.
2 I believe there are three screw holes for the disc reading part of the dreamcast and you really only need two to keep the disc player in place, so also try another hole.
3 and one last thing to check you haven't put a screw underneath the board already?
Nov 06, 2007 | Sega Dreamcast Console
I need you to explain more about your problem. Explain how your Sega Dreamcast is behaving. I'll be more than glad to help you.
Oct 26, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
187 people viewed this question
Top Sega Video Game Consoles & Games Experts
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
