Question about HP OfficeJet 6110 All-In-One InkJet Printer
I have a officejet 6110 and when I turned it on the other day the scanner moves all the way to the right but never stops and sounds like a gear keeps slipping. Then a scanner failure appears on the screen and tells you to turn off the printer and restart. I've done that several times but it always does the same thing. Could you possibly tell me what the problem is?
Mr.Coiroj
This kind of problem creating from main dust only in Scanner Assambely so it must remove and make it clean; while you making clean use Soft Cloth to all the Glass to Clean; Do Not Apply Any thing in the Glass try it....
Posted on Jun 30, 2009
After turning on computer, reoccuring grinding sound till eventually stops, printer denotes 'scanner failure' and prompts power off then on again!
Whats going on from the sound of it is something stopping moving the scanner up and down OR your scanner cant find its referance point. These dont normally bust a gear but do get dusty
You need to look at the scanner and see what it is doing on power up, is it trying to move as if threw the edge of the machine? (no white reference) so keeps trying and thats the noise the scanner movin a mm then another trying to find home but failing.. usally due to dirty mirrors or blown lamp..
Either way I'd watch a few times,... y0u know the lamp under the lid that moves up and down;0..
Yuor HP should turn on lamp and shine it in the inside edge of the machines copy glass near after power up
You can manual move it with power off to the other end and then after removing your hand plug it in and turn it on and see what the scanner does, I bet it moves fine untill it get near home then starts dancin untill it gives up throwin your error (aka dirty mirrors, just use clean lint free soft somethin, no chemicals just good clean of mirrors. or somethings stopping the carriage movin.
Let us know how you go.. Cheers
The Fix... if Im guessing right that is..... is to remove the Torx screws that HP use (need a a torx driver) that hold on the glass, it needs to come out so you can clean the scanner mirrors reflector and lamp (DANGER 240v live UNPLUG;) and ensure the systemt runs well up and down the scan rail, i think you have to fight to remove the plastic cover from the operations panel too,and on some the Doc feeder has to come off, but on yours I think its the op panel to go so you can get to a screw or something.
Dec 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Nois from the scannermecanism under initalizing
The problem is not in stop sensor.It's in scanner section.The scanner is not initialization couse inside in section has a to much ash on mirrors and the scanner lamp.Replace the scanner section or clean up it.
Sep 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Unable to power up.
The motor that moves the scanner head is not meshing correctly. It might be that the gear is stripped, or that the head is jammed. You can lift the lid and turn on to see if the head moves or just kind of jerks slightly. If the unit has been transported lately, sometimes a drop can misalign the rails the scan head rides on. You might be able to see the problem through the glass.
You can try to disassemble the scanner portion to free it, but just looking through craigslist showed two of that model for $40.
Aug 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
The printer is making a gear clicking sound.
I had exactly the same problem with my OfficeJet 6110 as reported above (i.e. the scan head not knowing where the end-stop is). This is how to fix it (this method worked for me) 1) Lift up the scanner/copier hinged lid. Around the edge of the scan glass are 4 Torx screws. Undo all four screws. 2) Carefully prise the control panel faceplate off. The buttons underneath are on a single panel. Slide this to the left and lift off. 3) Jiggle the lid of the scanner to get it off the main body of the printer. 4) Locate the scan engine motor (top right corner) and remove the two motor retaining screws (one on the left of the motor, the other on the right). 5) Lift out the entire mechanism (rod, drive belt, scan head) and turn over. 6) Thoroughly clean all glass and mirrored areas of the scan head. Also clean the scan lamp on the top of the scan head. Clean the tray inside the scanner (where the scan head travels back and forth). Also clean the inside and outside of the scanner glass pane itself. 7) Refit all parts, using the technique described above, in reverse order. 8) Switch on printer. It should now work OK. Hope this helps, guys.
Jun 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner Faliure
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
8011
Jan 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one
maybe you could try to reinstall the driver?
Oct 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Initializing self test scanner
http://www.fixyourownprinter.com/forums/inkjet/19182
Nov 19, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 scanner fault
There is a sensor on the right that is probably not working or is out of place. turn off printer and open door , move printhead all the way to the left and look at the right side of the printer, is anything loose there? ( the best way to describe it is to look for a piece that is like the symbol pi )
Nov 07, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6110 scanner carridge appears stuck
Unplug the power. Plug back in, while simultaneously holding hash (#) and (6) buttons, until S-reset is displayed (sometimes this can take like forever) but it is a documented HP mode.... Then set up machine using 1 key to confirm options and arrow keys to select options.
To enter another maintenance mode (fat lot of good that will do you), press and hold * and #, then press 1 and then 2 and then 3 (or 5) for a variety of different options, which include testing of the scan bed. This of course only works once the scan bed has initialised...
Or: take out all cartridges and close doors. Wait until it complains, or indicates a cartridge jam.
Regards
All-knowing.
Oct 20, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110
Is the ticking sound coming from the right side near the bottom? Or the left side near the top. If it is the right bottom then you're looking at a service station. If it is the left top then a scanner unit. Scanner unit is not available from Hp. You can try dismantling and cleaning all mirrors and lenses (usually doesn't work). If it is the service station, you are probably going need parts that are not availble.
May 01, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
236 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
