Question about Fisher and Paykel Washing Machines
Fisher and paykel smartdrive 5.5 turns itself off
Fisher and paykel smartdrive 5.5 machine turns itself off after a few seconds when it is on fill and wont do any cycle and has error code 00111001 .firstly i could let it fill a bit then go to wash cycle but now it keeps tripping itself off and wont do a thing.
abhishek33
  • 1239 Answers
SOURCE: smartdrive 051 wont stop filling
HI Servicing the Water Level Control Switch
This is another control panel switch, usually located next to the temperature switch. There is a small hose connected to this switch, and sometimes this hose becomes loose and falls off the connection. When this happens, the water in the tub usually overflows. To solve this problem, cut about 1/2 inch off the end of the hose and use a push fit to reconnect it to the switch.
The switch itself can also malfunction, resulting in tub overflow and other water-level trouble in the tub. If you suspect this switch is faulty, remove it by backing out the screws holding it in place. Take it to a professional service person for testing. If the switch is faulty, replace it with a new one of the same size and type. Connect the new switch the same way the old one was connected..PLEASE RATE IT......
Posted on Nov 16, 2008
  • 17 Answers
SOURCE: fisher paykel smartdrive 601
Most likely a blocked pump
Posted on Apr 19, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
  • 1531 Answers
SOURCE: fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Posted on Mar 08, 2010
Error code 42 on fiher and paykel top loader
42. (00101010) Phase 1 - Rotor Fault
Primary Source: The Motor Controller has had some confusing information feedback.
Action: Turn off SmartDrive at the wall and back on again after 5 seconds.
Restart.
Apr 04, 2014 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel smartdrive 053 fills really slow
Your cold valve could be faulty & need replacing.
Try swapping hot & cold valves to see if it fills faster.
Jul 12, 2012 | Fisher and Paykel Washing Machines
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel smartdrive 508 filling slowly
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Jun 18, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Smartdrive 708
The out of balance micro-switch is faulty/corroded. This switch is located under the motor control module on the right of the machine and is activated by a plastic lever that goes down beside the outer tub. Replace the micro-switch.
Oct 07, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
166 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
