Question about Car Audio & Video
Cd player has started not reading disc or sounds scratchy. is there a way to clean or fix/
  • 4 Answers
Believe it or not you can use cigarette lighter fluid on the tip of a cotton bud to clean the focus lens, the lens is not the lazer itself, thats in the bottom of the mechanism, the lens you can see is just a focus lens that becomes dirty, it kind of works like a telescope, the lazer is like where the eyepiece is on a telescope and the lens on the front of the telescope is the lens on the mechanism and can easily be cleaned with the lighter fluid, and since lighter fluid evoporates very quickly theres no worries, used it for years without a problem, be gentle though when lightly rubbing from left to right over the lens, getting to the lens you will need to take off the top cd clamp, usualy a screw either side with a spring, easily removed to be able to see the lens.
Posted on Jun 27, 2009
Zenith XBV443 no picture or sound after reading DVD disc
see this causes and fix it. God bless you
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Sep 30, 2012 | Zenith XBV443 DVD Player/VCR
My Allure TV is working well unfortunately the DVD isnt. I put the DVD in and it starts loading then says no disc. It sounds scratchy when loading. The TV works well but I use the DVD every day can yo
The only solution is buy a DVD disc cleaning kit and follow the instructions, this will clean the plastic lens and maybe get it back in working order. Second option is to buy a cheap DVD player in hopes the back of the set has the proper audio and video input jacks.
Mar 05, 2012 | Televison & Video
We had not used our Magnavox dvd/vhs player in quite awhile so I cleaned the dvd with cleaning kit, and also cleaned the actual dvd before we tried playing it. The dvd had a scratchy , static, sound...
Hello
Just put in a new CD into it and check whether it will read it or not. Check this with an MP3 CD also. If these two works, and the set does not recogonize DVD only, or it doesn't recogonize and read none of them, the laser unit asembly in your Philips set is damaged. Usually, philips laser units are of special types and should be replaced with same type and number. Never use any substitutions; none of the will match to it. Insist on original type and number. OK
Mar 11, 2011 | Philips Televison & Video
My cd sounds like it is scratched. it is not
sounds like the laser assembly is going bad...when the laser gets weak it will not track properly and it makes a skipping scratchy kind of sound...there are adjustments inside the cd player but I don't recommend that you adjust them...refer servicing to qualified service personell. You need an oscilloscope to make these adjustments. A laser will cost anywhere from 40.00 to 150.00
Dec 18, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Ripping audio CD-R's with Windows Media Player
    use a different ripping software, the best is Nero and it does many other work by finetuing the audio tracks...
    Dec 07, 2009 | Office Equipment & Supplies
    5 disc cd changer CC4000 will not read
    All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
    Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
    Numark CD MIX2 right deck skipping, sounding scratchy
    Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
    Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
    Console
    It may be that the laser is aligning itself after trying to run the disc, you may need to run a cd cleaning and aligning disc in the playstation, although, it maybe that the laser is on it's way out.
    Apr 29, 2007 | Sony PlayStation (PS) Console
    Various LG DVD Player
    Some models of PIONEER cd players had radio frequency problems that caused them to work on and off. Are you near any radio or braodcast towers? Poorly shielded power supplies cause this as well. A weak laser diode in the pick-up assembly in model runs could be the problem. You might want to Google the model number and see if this is common for these units.
    Apr 27, 2007 | LG DK 9411P DVD Player
    Car Audio & Video Logo
    177 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
