Question about Canon PC1061 Copier
Second blank page comes out after copies
If I make a single or multiple copies then my machine ejects an extra blank page.
    Sergeant:
  • 199 Answers
Check paper size setting and paper pickup
Posted on Jul 09, 2009
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Replace toner and drum and when i make copies they come out blank
This comes from the manual for your device:
A blank sheet is ejected.
You placed the document facing the wrong way when using the copier.
The other party placed the document in their fax machine the wrong way. Check with the other party (KX-MB781 only).
Try putting a page in and seeing if it copies blank and then putting it in the other direction. Have you had the same issue with printing?
If everything comes out blank it is the fuser or heating element.
Oct 25, 2012 | Panasonic KX-MB781 Laser Fax, Copier,...
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
Multiple page printing
if it's one original making 20 copies and doing the problem then you have a problem with the
a) Primary
b) Seperation unit
I would change the Sep 1st
Sep 08, 2008 | Canon PC-940 Black and White Copier
Hp business inkjet 2800
Sounds like your driver is sending A4 size documents, and you've got Letter in the drawer. When you do that, it runs out of room on the Letter-size page, since A4 is a tad longer, and has to continue onto a second page. Margins being what they are, the second page is usually blank.
Hope that helps.
Jun 20, 2008 | HP Business InkJet 2800 Printer
Multiple Copies
Replace the pcu cartridge. If you have already done so, check to see if it is turning. You may have a drive problem.
Jan 26, 2007 | Ricoh Aficio CL1000N Printer
Canon PC1061 Copier Logo
110 people viewed this question
old marine
old marine
