Question about Cobra Radio Communications
I have model PR170 Cobra microtalk 2 way radios. One of them you can hear the button toggle but no voice comes out. They are on the same channel and the volume is up. Yes I am holding the button down long enough. Any suggestions?
zeusfaber
  • 247 Answers
SOURCE: Brand New Cobra microtalk won't work!
Double check against all the instructions - in particular, make sure the batteries are charged according to "before first use" spec, that the volume is turned up, and that the squelch (if fitted and not automatic) is adjusted properly. If it still doesn't work, take it back to Wal-Mart. If the product doesn't work, there's no need for the packaging to be in good condition - it's not as if they'll be needing it to resell the goods to anybody else. A.
Posted on Apr 08, 2007
Gavin93
  • 66 Answers
SOURCE: Cobra microTALK PR 3500-2 DX VP 2-Way
The Cobra microTALK PR-3500-2 DX VP Radios are supposed to be equipped with acoustic noise filters that are built in the microphone. This problem could have been caused from the radios getting wet, damaged, or the microphone going bad, the microphone can be replaced if you still have the warranty, but if you want to save money you may wan to get a new set of 2-ways. I suggest the Uniden GMR325-2, these models are inexpensive and have an approximate 5 mile range in good conditions.
Good Luck!
Posted on Jul 05, 2008
Agent Ken
  • 250 Answers
SOURCE: transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jul 21, 2008
kditterline
  • 127 Answers
SOURCE: I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
Posted on Jul 16, 2009
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
Cobra microtalk Pr 17 OC
Dear sir,
Open the unit & check PTT switch check it by manually closing the circuit ..it will come in tranmission mode .i think ur PTT switch is out of order & nothing else .
Regards
Raj
Dec 11, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Tranmitting
one of the units may have a bad mic element. Can you hear the speaker unmute when the radio is keyed?
Jul 30, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Good Luck!
Jul 05, 2008 | Cobra microTALK PR 3500-2 DX VP 2-Way...
COBRA PR4700WX
Hello horndog78,
Your radio may be locked. You can confirm this by looking for a icon of a padlock on the screen.
To toggle the lock on and off hold down the LOCK/MODE button for a full two seconds until you hear a double beep.
Best Regards,
Ken
Go Ahead. Use Us.
May 02, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Cobra microtalk2 auto squelch not functioning
Dear sir,
Use maximum range button which is also light button ( keep it pressed for 5 sec ) u will hear a beep , then relase it operate ur radio in High power transmission mode , ( channel 1~7 ) or 16-22 ( ckeck ur country lcense guideline before that ) .
Regards
Raj
Apr 02, 2008 | Cobra microTALK LI6000-2 (14 Channels)...
Cobra two way radio
Rich,
This is a discontinued product, and at that price point, they're completely disposable. If not working properly, then toss and replace.
Cobra microTALK PR 245 Two Way Radio
Oct 14, 2017 | Cobra PR-245/2 (7 Channels) 2-Way Radio
Radio Communications Logo
73 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
