Question about Canon i850 InkJet Photo Printer
Will not print and keep getting paper thickness error
Will not print and keep getting paper thickness problem...changed paper no results
  • 3 Answers
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Posted on Aug 02, 2009
My printer pulls through up to 4 sheets of paper at once and then prints only on the top, so I'll have a printed sheet every 3-5 pages or a double sided print but with 3 pages separating the front and back...
Check your printer settings for paper thickness, ink quality, and check rollers for wear and dirt. Sometime if you change paper weight and finish , you will get better results
Jan 08, 2018 | Lexmark OfficeEdge Pro4000 - multifunction...
Canon i560 colour printing problem
have you tried changing the cartridge..?
Jul 29, 2008 | Canon Office Equipment & Supplies
Error 51.23 after paper jam
**Yellow laser scanner error, replace scanner assem..For tech guys: Remove scanner assembly, remove cover,check for yellow scanner motor rotation. if its hard or struck, gently remove engine motor,lubricate the shaft fix it back & verify rotation, how ever entire unit opened clean all reflector glasses with ear buds gently, fix the unit back properly.(out of four screws, factory wont fit one or two screws for alignment match, same way fix the screws, don't inter change). check for print if its rectified. process end..or else replace scanner assm..
Dec 21, 2011 | HP LaserJet CM1015 All-In-One Printer
My toshiba copier keeps saying job status change paper type. how do i get it off that? thank you
Your copier is likely trying to print to a different thickness of paper (ie thick 1/thick 2) then you have in whatever tray it is trying to print from. You will either have to change what is in that drawer via user functions or delete the job and try it again with a different paper type.
Sep 07, 2010 | Toshiba E-STUDIO 720 Copier
Paper thickness error Canon I560
Align paper to left or right. Try to print on other positions or Change paper.
Jun 08, 2010 | Computers & Internet
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
Thick paper won't print
check ur printer settings and try again if not soloves to and change the paper better to use thick paper
May 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Very slow printing
I'm not sure that there is a problem here.  The correlation between print speed and print quality,
especially on InkJet printers, is a negative one.  That is, the higher the quality setting, the lower
the speed. So, if you're selecting the greatest quality for your print option you will suffer the
lowest output speed.  This is because the printer is taking time to ensure that it prints each
minute detail onto the page.
If you are looking to keep the quality optimal, one solution may be to select a different grade of
photo paper (or perhaps one with a different coating [matte, semi, gloss]) and test to see if you
can lower the quality setting on these higher-end paper types and still achieve your desired
results.
To get what you want from your printing paper, you will have to consider what you like in a print,
how you intend to use your prints, and what you are willing to pay to achieve this at home.
Some things to think about include: paper thickness, color brilliance and resistance to fading.
1. Paper Thickness
When it comes to paper thickness, paper that resembles the look and feel of traditional prints
will be the best if you like to print a lot of photos and pass them around. Thick paper just feels
right in your hands and will also stand up better to handling. However, if you are going to put
the majority of your photos straight into an album, a thinner paper may work just as well for you.
2. Color Brilliance
To ensure the photo paper you purchase produces good color, you can purchase small sheaves
of a short list of photo papers which you think will suit you. Next, print a series of colorful test
photos on each to see which has the best color. If you can incorporate colorful photos that also
have prominent straight lines and people in them, you will also be able to check the quality of
sharpness and skin tones in the same test.
3. Resistance to Fading
Always try to check the resistance of the paper to fading. Simply take your batch of test photos
and tape them to the window that gets the most sunlight throughout the day. Then, before you
go in to pick up a batch of replacement paper, check to see which photos, if any, are showing
signs of fading. Any paper that shows signs of fading in this short time frame should be avoided.
4. Changing Your Ink
It is also important to remember that any time you change ink for your printer, you may find
yourself getting dramatically different results.
Jan 09, 2009 | HP Photosmart 2610 All-In-One InkJet...
Canon i850 InkJet Photo Printer Logo
304 people viewed this question
old marine
old marine
