Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman riding mower blades will not engage
Craftsman riding mower (26 HP 54" deck) blades will not engage when switch is pulled. Blades quit in the midst of mowing.
  • Pastor J.D. Sherman Apr 24, 2013
    this is not the solution. it is the throttle cable not the blades..
  • 513 Answers
Maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 1 more comment
  • Jose Luis Gutierrez Jul 03, 2013
    But Why does the mower turn off completely after trying to engage blades and won't turn on again
  • Wade Mobley
    Wade Mobley Nov 09, 2017
    They also have a safety switch if by accident you try to go into reverse without pushing reverse button or turn ignition switch back to engage reverse. They will shut off and not turn back on unless your going forward.
  • Wade Mobley
    Safety switch under seat will kill the mower completely on most tractors if parking brake isn't set while trying to get off mower with it running. We can only give you a very good solution on what it could be. Without seeing it in person.
Blades won't enGage motor dies
First unplug the plug wires, take key out of switch, then check to make sure that the blades will move by hand. there could be a dirt mound or rock jammed in there
Apr 22, 2014 | Craftsman 26 Hp 54" Deck Yard Tractor
My belt keeps sliding off i have a 52 inch deck 3 blades . need diagram
Your owners manual should have a diagram. If you don't have the manual, you can download one here. You will just need the Craftsman model number of your machine.
http://www.searspartsdirect.com/partsdirect/product-types/Riding-mower-tractor-Parts
Mar 23, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
CRAFTSMAN 26 HP 48'' DLT2000 MOWER ELECTIC PTO CLUTCH SEIZED UNPLUGGED BUT BLADES CONTINUE TO TURN. CAN IT BE REPAIR OR MUST IT BE REPLACED?
I would say replaced to ensure correct opperation.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Blades will not engage, belt not broke but is very old, do I need new one?
Check if the belt is loose. With the engine off, try to pull the mower deck belt around by hand. If you can pull it easily, and the blades don't turn, then replace the belt. If it's hard to pull, and you can see the blades try to turn as you pull it, then your problem probably isn't the belt, but the PTO clutch or mower engage switch.
Jun 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 25 Hp with 46inch deck. The blades will not engage when the pot switch is pulled
one of 2 things keyway sheared off on the engine pulley or saftey switch on the lever to engage has shorted out
Jun 29, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a Sears 26 hp garden tractor that stalls when I let off of the clutch/brake or engage the mower blades. I have bypassed the under seat swith, and I have also bypassed the clutch/brake switch. The...
does it run off of a pto system or is it a lver type if its a lever type there is a switch under the lever also you might have something caught in the deck causeing it not to engage blades if i can further help e-mail me wade at wadembly@aol.com
Jun 24, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Apr 25, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
3,407 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
