Question about Frigidaire GLTF2940ES Front Load Washer
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to complete the load you have to set it on drain and spin only setting. I even downloaded the tech manuals and an E70 is not even listed! HELP!!!
  • 3 more comments
  • Anonymous May 26, 2008
    Don't think it is the cold water line. Seems like the valve is trying to activate, maybe a solenoid problem?
  • Neeneego May 26, 2008
    I moved into a new house and am having trouble with my washing machine. Error Coed E 070. This house has really bad water preasure and originally the line for the hot water was leaking. The owner sent over a handyman to fix the problem and now I keep getting the message E 070. I had a feeling that now there is no cold water because when I turn the valve there is no sound like water running.
  • tfrye Jan 09, 2009
    I have had the same problem on the Gallery Series Washer from when it was new. My problem seems to be only when doing larger heavier loads like towels. I thought it had to do with load balancing, but there could be a deeper problem with the machine
    CAN SOMEONE HELP!!!!!!
  • chinguek86 Mar 06, 2009
    I am using washing machine of Toshiba brand. An error of E7 shown on the child proof column which it shuts down my machine automatically after the ON button is turn on. I tried to shut down and restart my machine again but it doesn't help at all. What is actually meant by E7 and how could i solve this problem? Thanks
  • Anonymous Apr 08, 2009
    E70 error kenmore front loader washing machine. Will not complete cycle. Anyone know of a fix ?
    Ben
  • 4,889 Answers
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Posted on Nov 06, 2007
I have a little problem at my washer toshiba aw-9000s. The display screen E7-4. Please give me..what ur solution
Posted on Aug 16, 2008
"E7" the power line is miss, please check the circle power line and re-connect line again in back of Wash machine.
Posted on Apr 13, 2009
    New Friend:
I have problem with my toshiba washing machine aw 9790sm, it keeps shos E2-3 code, why? somebody help me
Posted on Feb 19, 2013
I have a little problem at my washer toshiba aw-9000s. The display screen E5. Please give me..what ur solution
Posted on Nov 11, 2010
All, solution #1 is indeed correct. After many frustrations and erroneous advice I decided to try the aforementioned advise. In fact, I found out that by turning both levers to the "off" position then turning each on individually, cold water would not even despense into the washer, however, the "hot" would. I switched the hoses and have not had a problem since. Eagle 338 "you are da man."
Posted on Dec 27, 2009
Solvent problem for code error E7-4 (Toshiba),you must be replace sensor regulator because not detec not run the same as overload motor drive, please your buy sparepart only customer service
Posted on Aug 14, 2010
After doing a wash there are white particles all over the clothing. I installed a water filter, I have changed the washing powder to a liquid laundry soap but still have what looks like chucks of water scale all over the clothing. I live in Bangkok and we do not use hot water. Cold water only. The machine is 6 years old used every day and still runs great. suggestions please. regards rickmen
Posted on Jun 26, 2010
I also facing the same problem. Please us to resolved it ..
Posted on Nov 09, 2008
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Posted on Aug 04, 2007
  • 641 Answers
SOURCE: E10 error
The error code chart indicates that this could be a water flow problem, too low of a drain hose height. Check for clean filters of the inlet water line. Check that the drain host was assembled as per the manual's instructions. In any case your machine is still under warranty and you can ask for Frigidaire's assistance. Good luck!
Posted on Sep 06, 2007
tbirdfan1
  • 3051 Answers
SOURCE: My frigidaire front load washer will start a wash,
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Posted on Aug 15, 2010
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
Frigidaire front load washer. E46 error. replaced control board. Still have same error code. Is there a way to clear the error code and reset the washer with the new board?
Hello CJ Lou - Typically that is correct, error code E46 indicates to replace main control board. First, either unplug or flip the household circuit breaker off to the washer to reprogram it. Wait approximately ten minutes and restart unit. Then try pressing and holding the START and PAUSE/CANCEL buttons simultaneously. All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the START and PAUSE/CANCEL buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes. If it proves to be ineffective, contact a professional to accurately pinpoint any potentially more serious issues.
Jan 30, 2013 | Frigidaire ATF6000ES Front Load Washer
E90 error
The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
Wont start
First you have to find the error code.
So! To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Dec 03, 2011 | Frigidaire Affinity ATF7000E Front Load...
Water does not go into washer
Wait 5 seconds
As long as the buttons are held, the failure code will appear in the display as an Efollowed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Washes starts buzzing and blinking and says e70
The e70 error code comes on when the hot and cold water hoses are reversed or not properly installed.
Feb 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
Every other load we have OE coming up, also the drowm will not spin
LG washing machine error code - OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc
Nov 28, 2010 | LG WM2277H Front Load Washer
Stops within cycle E70 is error message
E70 Means that the Hot and Cold water lines are backwards. Switch the lines and cancel out the cycle. Turn the dial to drain and spin and pump all the water out of the unit. Then restart the cycle and it should be fine.
Feb 26, 2010 | Frigidaire ATF6000ES Front Load Washer
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
5,568 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
