All netgear routers have the same default user names and passwords, so unless you have changed it you should still be able to use the default one set by the manufacture.
IP address: 192.168.1.1
User name: admin
password: password
This is the default info for netgear.
If you are looking for your wireless password it will be found in wireless settings of the router on the admin page for your router.
SOURCE: cannot get password authorisation for netgear router
The default username and password for the Netgear DG834G router is:
username: admin
password: password
If that does not work (i.e., the default password has been changed), then the only way for you to log into the router is to restore the router back to its default factory settings. Then you will be able to use the default username and password above.
To restore the router's factory default settings, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
Default user names:
