Question about Canon PC1061 Copier
Our PC1061 has been wonderfully reliable. Very recently we have 2 copier problems: One problem is there is frequent paper jamming coming out of the paper tray just below the toner cartridge and secondly, when copying, a second blank sheet of paper comes out.
  • Anonymous Mar 15, 2014
    Canon pc1061 paper jam
  • 125 Answers
Hi:
Slide the drawer out completly and look into the cavity on the right side. You should see two D rollers that pick up the paper form the paper cassette. Clean these with alcohol. They an get dirty with time and cause paper jams.
Good Luck
Andrew
Posted on Jun 27, 2009
After working fine for 2 years, my Brother HL-5370 started frequently jamming and wrinkling paper.
You need to make sure your paper roller is proper working if it creating any problem then you need to check there settings then it will start working fine . Renew your printer pickup roller No more paper jams Don replace rejuvenate... Frequently Asked Questions
Feb 21, 2015 | Brother Office Equipment & Supplies
The adf no longer works, it starts to run the paper through and then it gets stuck and prints out a blank paper
Clean the ADF paper feed and separation rollers,and verify the paper jam way and the mechanical paper transmision components.
Mar 18, 2013 | Canon PC1061 Copier
I have a Richo 2035 black and white copier. Recently the copier has begun to paper jam...and its done frequent every time i clear the jam..it runs for a while maybe 10 copies and jams again. What can i do?
Not surprising - it may need some service. It is 7-8 years old. There are a few areas that could be affecting output. Most likely you need to replace the rollers that pick the paper out of the tray (3/drawer) -especially if the problem occurs with 1 specific tray. Try using another tray to isolate the problem
Jul 10, 2011 | Office Equipment & Supplies
Paper jammed in fixing assembly and technician says fuser assembly is $800.00
Is that for the gold plated version?
http://www.precisionroller.com/search.php?q=pc1061+fuser
Here is one for $179.95 and I suspect you might find them cheaper. I use PR all the time and they have free shipping.
Good Luck.
Sep 20, 2010 | Canon PC1061 Copier
Printer will not print...it jammed ......the paper jammed in the machine..and I pulled it out....
1. Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
2. Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
3. If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
4. Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.f you have a laser printermag-glass_10x10.gif, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
5. if you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available atelectronics shops or drugstore.Try changing the toner or ink cartridge.
Feb 04, 2010 | HP Office Equipment & Supplies
Says rec paper jam slide left platen
check as follows. Give by turns several sheets. Localize, where paper is stoped attentively see that can disturb her(its) motion. Follows to pay attention to presence stranger subject ( such can be) , then, when you find, place of the constant grip, analysing reason, can is there jammed ragged paper, can was torn off protection of the corona, it wore slantings gross, please ask, beside who has occurred jam and that herewith occurred. I ?????? with this technology 20 years and always in such events ask, as this has occurred. Most often this reason scrap papers, which is not seen, hereinafter stranger subjects, even feminine emery board and staples. You manage, in this nothing complex.
Sep 13, 2009 | Canon PC1061 Copier
Only 8 1/2 by 14 paper jamming at the DADF
Does it feed sometimes, and just jams frequently, or every single page?
Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
Mar 16, 2009 | Office Equipment & Supplies
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
Paper jam/feed problem
ok i have the freakin same problem and the only i have in mind is that GET A NEW ONE printers are **** these days, makes me wana throw them out of the window lol but if ya need to print something important i suggest u go to the library ahh w,e....
Oct 03, 2008 | Dell 926 All-In-One InkJet Printer
Canon PC1061 Copier Logo
365 people viewed this question
old marine
old marine
