Question about Mtd Garden
Replacing drive belt on yard man lawn tractor
I replaced the belt on my riding mower that goes from the drive shaft to the rear pully on transaxle. Now the brake pedal locks when you push in down and the gas pedal will not work. When I put a spring on the gas pedal where it won't go all the way back it works okay. How can I adjust the brake and the gas without the spring on it?
Model #AT604G401 Serial #1129H10025
4 Suggested Answers
SOURCE: i need a diagram for a yard man lawn tractor where
When foot brake (clutch pedal) is pushed down and placed in park my tractor still go forward at almost full speed No matter what gear i am in or if it is park (forward or reverse) it still moves forward. Any thoughts
Posted on Jun 28, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
How do I put the drive belt back on my yard man automatic riding lawn mower?
The v side of the belt goes in the v of the pullies and the flat side of the belt rides on the flat pullies. It looks like the flat idle pully is bent out of alinement. The one showing in video with no belt on it that is the last pully the belt runs on before returning to engine. The belt comes from the engine to a spring loaded flat pully, to v pully on right of mower ,to v pully on left, to flat idle pully // that looks to be bent // then back to engine. Put belt on all pullies saving the spring loaded pully for last.
Apr 09, 2013 | Garden
How to replace transmission drive belt on Troybuilt model 13wx79kt011
?l=troy_bilt&p=76907616%5c0001&nd=0&z=30
THIS SHOULD HELP YA IVE DONE THOSE THAY ARE KINDA HARD THE PULLY ON THE MOTTER IS HARD TO GET OFF YOU MAY WANT TO TAKE THAT IN TO A SHOP
Nov 06, 2012 | Mtd 46" Dozer Blade, Fits All & Yard -...
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Aug 15, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
John deere mower won't engage
on the engine there is a shaft with 2 pullys ,drive belt goes to the top closet to the engine lower pully is for the deck
there also is a saftey switch located on the deck which should shut down blade operation when raised. check the mandrels for broken bearings by grabbing the pully and wiggle them back and forth looking for movement could be possible that one madrel is shot giving you that bad sound which is crushed bearings
Jun 30, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Honda HTR3009 riding mower runs great but won't engage in any high speeds. It slowly goes forward and in reverse - no power. When cutter is engaged, it won't move at all. What might be the problem?
sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
Jun 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I need to replace two belts on mtd mower i have no manual
im guessing your question is about the diagram for the direction of belts and which pullys they go on?
i would google it.
google the qeustion but in qeustion somwhere state that you need the belt diagram 1)engine drive belt
2) mower deck drive belt
Jun 24, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
1,387 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
