Question about Delphi SKYFi XM Radio Receiver
Delphi SkyFi3 will not play through the FM radio into the speaker
Have tried all non used frequencies in the D.C. area and set frequency to match on SkyFi3 receiver; nothing...just continued static.
I tried all the freq
Posted on Jun 28, 2009
Can I add FM frequencies to my receiver?
Unfortunately no. Use an AUX input or a 'stand-alone' FM transmitter.
Jun 13, 2014 | Delphi SKYFi3 XM Radio Receiver
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
Jul 19, 2010 | Delphi SKYFi3 XM Radio Receiver
Trying to figure out what FM frequencies are avail for my portable XM in my car? 50595 is my zipcode.
KQWC 95.7 is the only FM station that is out of webster city which is the 50595 zip code.
Jan 27, 2010 | Delphi Roady XT XM Radio Receiver
The Skyfi3 receiver will "self-mute". Is the mute frequency the same as other phone devices or TV remote controllers? I have the Skyfi3 in the kitchen, could an appliance cause this?
Yes, if you mean XM reception. Your microwave oven is actually a radio transmitter near the Satellite Radio frequencies and when you use your microwave, it WILL wipe-out XM radios. Even my neighbor can do it to mine! Check it out - boil some water and watch your signal fade in and out! You're going to want to move the radio, or use a 'repeater' for it, or use the playback of prerecorded.
Oct 29, 2009 | Delphi SKYFi3 XM Radio Receiver
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Cannot set fm frequency on radio
Go through the Settings Menu on the Reciever until you see Frequency Select It and then turn the dial until it matches the same frequency that you are using on the Radio.
Jan 01, 2009 | Sirius Satellite Radio Receiver
Match frequencies XM to Tuner
You should be able to go to the menu on your unit as long as there is not a plug in the audio out socket, and it should give you the FM Frequency option. If you remove the plug from the audio out, you will want to power the unit off and back on to get the FM option to appear when you push the menu button.
Nov 03, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi SKYFi XM Radio Receiver Logo
373 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
