Question about Phase Linear UDV9010 Car DVD Player
How to assemble the phase UV7i dvd/cd player
Hi, my radio start ejecting any cd/dvd I tried to play. I open the radio and found a plasic piece and a spring inside the player. the thing is I don't know how to assemble the radio again. The spring looks has no utility inside :)
Can u give me some info about how to identify the power supply wire to a car cd player
Posted on May 20, 2011
My Phase Linear UV7il accept only some CD's
the head unit is not reading due to incompatibility with thebrand or type of disck
Dec 29, 2009 | Car Audio & Video
My UV7i just opens and closes as it pleases
Some loose connection on the LCD panel to the device, or inside the LCD, by a certain vibration the monitor seems to get like a christmas lights one on/off..
you better bring it to a certain service technician to provide through test on your device.
thanks
Feb 23, 2008 | Phase Linear UDV9010 Car DVD Player
How can i watch dvd while i drive?
its very sample. you will insert a DVD and everything will be start and going automaticly.
May 29, 2009 | Phase Linear UDV9010 Car DVD Player
Factory cd player wont play burnt cds
A '96 CD player can't see newer burnt Cd's. Found that out with my '99 Chrysler.
Feb 26, 2009 | Phase Linear UDV9010 Car DVD Player
Bad disk
Wow! That's a first. I used to sell both the Jensen AND Phase Linear versions and never a problem. It sounds like a bad unit. You say it plays NOTHING? No CD's OR DVD's that are the factor made?
The only thing I hav up my sleeve is to do a reset on the unit. If it has a button (I don't think it does frm what I remember) use it first, then with the unit ON, unplug the poer plug, wait a few, then plug back in and see.
Sorry I have no more tricks foir that,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Jensen VM9510 Car DVD Player
My phase linear uv8
Hi
The Laser Diode inside the UV8 that reads the DVD media is most likely set too weak for the amount of dust built up in over time. This dust block the laser optics and causes the player to not read DVD's. You will want to go get a bottle of air from Radio shack and blow the DVD player out. The reason it is reading CD's is that its laser diode may be set stronger and is able to break through the dust. There are two Laser Diodes, one for CD, and one for DVD. Good luck. www.PlaystationClinic.com
Sep 04, 2008 | Jensen VM9510 Car DVD Player
Jensen uv7i
did you try resetting the unit?
May 29, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
Phase Linear UDV9010 Car DVD Player Logo
203 people viewed this question
Top Phase Linear Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
