1998 Toyota Camry Logo
B
Bryce Hancock Posted on Jun 28, 2014
How do I get rid of high pitched whistle in cabin air system?
My '98 Camry makes a high pitched whistle from cabin air vent, and intensifies as fan is turned higher. It primarily is when air is directed straight at front passengers, and sounds like something is caught in the vent. Any ideas how to proceed to with seeing if some debris is caught in the cabin air system? I do not seen anything when just looking in vents on front and top of dashboard.
Apollo Morelos
Level 1:
  • Contributor 31 Answers
  • Posted on Jun 29, 2014
Apollo Morelos
Contributor
Level 1:
Answers
31
Questions
Helped
10491
Points
44
Blower motor might be going out. worn out bearings.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Aug 10, 2008
SOURCE: 2000 Camry LE bad odor from a/c heater cabin vents
Possible the smell is coming from the bacteria living on your ac evapourator. You can buy a spray for this that you set off inside the vehicle. Follow the instructions on the tin.
Anonymous
  • 11896 Answers
  • Posted on Apr 07, 2009
SOURCE: No hot air at rear vents on 98 Toyota Sienna CE
Possible that heatcore is going or hose from heater is leaking or falling off.
You can go to www.autozone.com and see a full free online repair manual for your van
Anonymous
  • 12 Answers
  • Posted on Jul 09, 2009
SOURCE: A/C blows from defrost and floor vents, nothing from dash vents.
the switch where you turn it to blowing at your head is probably out. you will need to replace the switch control where your defrost, foot, head etc. what make, model, year is your vehicle?
Anonymous
  • 59 Answers
  • Posted on Sep 07, 2009
SOURCE: Passenger ac vent cools and driver side ac vent do not
It sounds like a heater blend door issue inside the heater box that is actually not closing all the way to allow either cool or hot air or visa/versa.
Anonymous
  • 118 Answers
  • Posted on Jun 15, 2012
SOURCE: Air is not blowing through my 02 Camry front vents. It sounds like the fans are working but no air is coming out.
I would say the blend door actuator is not working right. It directs the flow in the vent system.
I have a riello burner BF5 and it is making a high pitch whistling noise. I am waiting for a professional repair person to come but just wanted to know if it is dangerous and have any safety concern.
Does the whistle start when the house air circulation fan starts?If so,it's just a leak in the air ducting,not much to worry about if it is that.
Fan making high pitched whistle
check for debris in the air intake. I've had leaves in mine make a similar noise
1999 nissan frontier
some high pitch whistles can be from the brushes of the alternator needing attention
it may be from failing idler pulley bearings
check for vacuum leaks at hose connections
3answers
High pitch whistle on my 1998 wrangler 4cyl auto
loosen the gas cap and see if it still does it
If it goes away check the venting of the tank
1helpful
When window is down, i get a high pitched noise in the cabin of the car
This is got to be the best one I've ever tackled! Got a few questions, does changing the position of the window change anything? It could be the door seal on another door or window that in inducting a third vent and causing it. It could very well be something in your vents, got children? Try changing positions of vents or get someone else to drive while you play detective. Almost be willing to bet that if you get someone else to drive while you hunt it , it want whistle. Technically speaking Air has to pass through a certain size orifice or be bent to a certain angle and pass faster at one area than it is in the other areas, if that makes any sense. It didn't to me when I read it. Sorry I can't be of more help but look at the good side, it'll keep you awake while you're driving!Not much help on this one~Gillight
1helpful
2answers
2004 Jeep Liberty makes high-pitched whistling noise when letting up on accelerator
with engine off check fan blades and shrould (plastic around fan) for cracks or if loose also check tailpipe bent at end if you backed into something. also check air filter box to make sure its tightly shut.
1helpful
2answers
Whistling noise while driving
If it is whistling while you rev your engine (while parked), then most likely there is a leak or hole in your air intake or vacuum hoses.
Facts:
1. Your car creates a vacuum to constantly receive air from the outside.
2. A whistling noise is created when air travels through a hole.
Check all air pressurized ducts for holes or leaks.
Check air intake system for holes or leaks.
Bad smell from heater is there a filter to replace some where? how do i get rid of the smell?
IF YOU HAVE AIR CON THEN YOU WILL HAVE A "CABIN FILTER" WHICH NEED TO BE REPLACED AND THEN USED A AIRCON CLEANER TO REMOVE THE BUGS THAT CAUSE MILDEW IN THE VENTS
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
