Question about Danby DPAC8020 Air Conditioner
EverStar MPM2-10CR-BB6. Comp. only runs for about 30 sec. then shuts off. Air is cold while the comp. is running. Fans continue to run. Fan slows then speeds up. Blows hot air for a couple minutes. Comp. comes on and symptoms are repeated. No error codes. Whats up? Unit is 1yr old.
    New Friend:
  • 7 Answers
Check the start gear for the comp.
Posted on Jun 27, 2009
I have a Beverage Air Sur 60 and unit powers on the inside fans run also the compressor and fan in the back run but unit doesn't ever cool down any ???
first are the evap coils one big ice block? if so melt the ice and look for a air gap in the door gasket. the comp. turns on so the thermostat is sending the signal to turn on. on these the drain from the evap (cold part/ top) could be blocked. blocked drain, water sits, then freezes and blocks air flow
Apr 08, 2014 | Refrigerators
The temperature will not adjust. none of the refrigerators are getting cold but fans are running
Sounds like you may have a compressor issue to me. if the fans are running that tells me the tstat is calling for cooling and the fans are running so they are fine. The comp is not producing cooling for some reason. Can you see the comp and tell if its running or not?
Aug 14, 2013 | Husky HUS-CN15 Wine Chiller
Nc6000 comp. will only run fan when turned on for
RAM shaken.
Go to service centre and they will readjust it for u.
Apr 16, 2010 | HP Compaq nc6000 Notebook
Does not make cold, main compartment or freezer, replaced "relay/overload" capacitor (?) but still cycles/clicks off and on - lights on and motors run but no cold.
if clicking off and on I would say . the relay is working but the compressor is not starting . if comp will not start ( no cold ) the fan by the comp runs when the comp runs / but if comp does not start the fan does not know .. if comp runs the lines one is small and other is larger . the small one gets hot enough not to touch.it . not hot no cool . I think you have a compressor problem .. **** hope this helps . get back with me .. //mm
Jan 06, 2010 | Amana ABB1921DE Bottom Freezer...
I have an everstar portable air cond. and the compressor stays on. when i shut it off you can hear either the fan or compressor still running. how can i fix this problem? I have clean out all components...
you have a stuck relay. you will need to find out if its the fan or the comp then trace the wiring back to the relay, once you have done this with the unit unplugged remove one wire then plug it back in if the unit stays off you have found the problem.
Aug 24, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Roper Refrigerator/Freezer side-by-side
1. check the motor compresors working touch the top 2. if the motor comp. working 3. touch the high side of the tube of the motor comp. if to hot the freon is ok if not. 4. cut the low side of the motor comp. plug and on start to pumping the motor close the hole of the low side tube using your finger hold 30 sec. and then open if the presures ok 5. the problem is freon
Sep 22, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Danby DPAC8020 Air Conditioner Logo
1,366 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
