Canon PIXMA MP240 All-In-One InkJet Printer Logo
Naoko Hashimoto Posted on Jun 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code error 6
Getting E6. how can I fix it ?
jeff5may32
Level 3:
  • Master 1,258 Answers
  • Posted on Jan 12, 2015
jeff5may32
Master
Level 3:
Answers
1258
Questions
0
Helped
375591
Points
5289
Could it be a canon pixma? e06 means "paper output cover open". Close the paper output cover.
http://www.canon-europe.com/Support/Consumer_Products/product_ranges/printers/pixma/error_codes/
Thomas Smithbrother
Level 3:
Top Expert:
  • Canon Master 3,698 Answers
  • Posted on Jun 28, 2014
Thomas Smithbrother
Canon Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
957052
Points
10318
My treadmill LIFE FITNESS T3 blocked and the console display the following message : ERR 6 / ERR KEY BLOCKED. Turn ON /OFF. Does not fix the problem. What does it mean and how to proceed? Thank you.
How do I fix error 6 on my treadmill?
E6 Error: Controller malfunction. Resolution: Ensure that the cables connecting the console and the controller are secure. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.Sep 23, 2021
E6 Error Code: Control Board Malfunction - Spirit Fitness Support
https://www.google.com/search?q=LIFE+FITNESS+T3+ERROR
My voltas spit ac showing E6 error just after installation
It is under warranty, bring the installation people back.
Voltas AC error code E6 fix - Check the voltage on the inside unit. Check communication signal wiring between inside and outside units for poor connections or an open wire.
Apr. 30, 2021
Voltas AC error code E6 explained: How to fix error code E6?
https://www.republicworld.com > ... > Gadgets
2answers
Hi I just bought a defy 13kg aquawave top loader & it washes but won't pour water to rinse after washing it just ends displaying E6 error can someone help pls
Defy error code e6
The E6 error is telling you that the clutch is causing the error or fault. This fault can happen if a paperclip, nail, coin, or a different object is jammed in between the tub and pulsator.Nov. 30, 2017
LG Top Load Washer Error Code E6 - How To Fix?
Videos as well
https://www.google.com/search?q=defy+13kg+aquawave+e6+error+code
I have zamil classic ac error code e6 what is the problom
An E6 error code is a communication error that the inside unit is not able to communicate with the outside unit. This includes the high voltage and low voltage lines. What Causes an E6 Code on a Mini Split? Wiring. Open or Bad communication wires.
https://www.hvachowto.com/how-to-troubleshoot-and-fix-a-mini-split-e6-error-code/
HOW DO I FIX AN AIR CONDITIONER DISPLAYING E6?
Hi this link is a13 page error code manual for air conditioners, Hope this helps....
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
2answers
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
2answers
3answers
What does the E6 error mean
Hi Cheyenne,
Most of the time an E6 error code refers to a restriction of water in your power pack. When you don't have enough water flow the power pack shuts itself down so it does not over heat.
Possible reasons are dirty filters, air locks, restrictions of water flow,
Solutions are to make sure your water flow is as best as possible, clean your filters often, remove debris from your hot tub, and remove air locks from your power pack.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
26helpful
3answers
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 • Cooktops
old marine
old marine
ZJ Limited
ZJ Limited
