Question about Whirlpool Dryers
LGR7648KQ1 model, dosen't seemd to have in lint in
LGR7648KQ1 model, Electric Dryer, dosen't seem to collect any lint in lint screen and now makes a thumping noise when drum is rotating. Dosen't seemed to dry well either?
  • 560 Answers
The thumping noise is a stress crack from poor construction when thr drum was made. I have the exact same problem and found the crack when I removed the top cover by removing the rear upper brace support screws and bracket, then sliding the top dryer panel towards the rear about 3.5" and then lifting it off for complete drum inspection. Rotate the drum by hand and you will see the crack...Mine is at the front, next to the drum seam.... We should all get together and file a class action suit...I'm sure this is a manufacturer fault related problem with this model..
The crack is probably allowing air to bypass the normal air flow through the filter too... Richard
Posted on Jul 29, 2009
Gallery
First thing is to check that your dryer is venting properly. If it is restricted this may occur. There are vent cleaning kits that you can purchase to make it easy to clear your vent from the rear of the dryer to the outside exhaust. Check were your link screen slides in at and inspect it for excess link build up. Any more questions you can contact us a dryer repair service.
May 20, 2013 | Frigidaire GLEQ2152ES Electric Dryer
F @ P DEGX2 lint trap problem
If you are collecting more on the outside of the house means the lint filter has a tear in it and the lint in being pulled through the tear and pushed out the exhaust. It sounds like you need a new filter but this isn't cheap. If you do it your self it will run about $70 if you get a repair man it will cost about $150.
Feb 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Our GE gas dryer is burning clothes that are fleece fabric or blankets. Any suggestions?
I recently solved this problem on my ELECTRIC dryer by taking apart the lint collection area. Some dryers allow you to do this by removing a couple screws surrounding the lint screen holder. Others require some dis-assembly of the top and front panel.
Once you have access behind or below the lint screen, use your hands or a strong vacuum (shop-vac) to clean out any collected lint that has fallen below the collection screen and settled in the exhaust duct. I pulled out about 100 cubic inches (~1.6 liters) of collected lint, cat hair, and debris that was obstructing air flow.
Obstructed airflow can cause metal parts near the electric heating element to overheat and scorch clothing and is a serious fire hazard. I expect similar problems can occur with gas dryers.
Dec 28, 2009 | GE DBL333GB Gas Dryer
Whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Jun 14, 2009 | Whirlpool Dryers
Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
May 12, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Lint screen is warped and does not collect very much lint
If the dryer is less than a year old the lint screen should be covered by warranty I would replace the lint screen to see if that helps.
Jan 06, 2009 | Kenmore 67082 Electric Dryer
Whirlpool dryer
You need to check the dryer INTERIOR to ensure there's no lint accumulations on or around the heating element. The exhaust systems on dryers are not perfect and SOME lint often gets by the lint screen and can start the collect inside the dryer. The lint will begin to smolder and give off an odor if it sits on the heating element housing. Make sure the dryer is unplugged before attempting to access the interior. If the model number you provided is correct, the heating element will be located under the drum on the right-hand side. You will need to lift the dryer top and remove the front panel (with the door) to access the inside and vacuum. Let me know if you need further assistance. I hope this information is helpful to you.
May 08, 2008 | Whirlpool LER5636P Electric Dryer
Maytag Electric Dryer Atlantis MDE7600AY
sounds like you have a restricted vent . check not only the hose but also the house venting. usually clogged at the screen or flapper outside. another ppular place for a buildup is the inlet under the lint screen. without proper airflow lint collects on element. take care of the quickly as it could lead to a fire.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
