Question about Plumbing
3E-34N spa pump, very hot to the touch. Motor is
Little Giant 3E-34N spa pump, very hot to the touch. Motor is full of oil.
  • 832 Answers
Put a clamp ammeter at one of the electrical supply wire and take note of the running current reading (amperes) with the motorpump running. Compare this with the rated current of the motor. It must be lower or equal to the rated current. From your comment that it is very hot to touch, I assume that the running current reading is higher than the rated current. To lower the running current, install a service **** or flow control valve at the discharge line. Then, put back the clamp ammeter at one of the electrical supply line/wire. Start the pumpmotor and slowly close the service ****/flow control valve until your running current reading is 85% to 90% of the rated current (amperes). I can assure you that the motor temperature will be lower.
Posted on Nov 25, 2009
Little gaint 3e 34 n pump has started cycling off for 1 to 2 minutes the back on. this happens once every 2 or 3 days.
this sounds as if the thermal switch is being activated , this ocurrs when an obstruction has entered pump , by design the pumping media (water?) is the cooling for the pump , low to no flow no cooling !!
Aug 19, 2012 | Little Giant 3e 34n, 1/15 Hp, 670 Gph Dual...
How do i drain a jewel plus spa,
Most of this manufatcturers spas have a 3/4" drain valve tucked in between the control pak and the pump. If your does not have this, a sump pump connected to a hose is the best , fastest way to drain a spa. My favorite king is "little giant" which is sold at any lowes or home depot if your in america. If not, any local hardware store should stock these. Cost in USA is about $35
Apr 10, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
This is the second time I have replaced the pump with no good results. This pump drains a pedicure chair. Some times it will drain sometimes not.Motor runs, with water going to inlet,but no flow out.really...
The #4E must be run submerged. The #3E may be used submerged or in-line. IMPORTANT: When
used in-line, the #3E must be installed so that the pump head (volute) is flooded before starting. That is,
the inlet of the pump must be below the level of the surface of the liquid being pumped.
Feb 04, 2011 | Little Giant 3E34N Dual Purpose Small...
Little Giant pump 3MD-SC set screw on motor shaft in loose. When tightened the rotating part of the pump drags on the motor housing. Am I missing a spacer?
The set screw is to hold the rotating part in place while
running. The rotating part is the impeller. It means that
the impeller has a worn out shaft hole. This needs a
spacer enough to be tightened without touching the
pump housing. We call it shims. This is a brass strips to wrap around the shaft. Otherwise, it must be replaced.
Just send in your e-mail for further assistance.
Aug 10, 2009 | Little Giant 3 Md Sc Pump Head Less Motor
Little Giant Pump - dialectic oil to use
ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Jul 29, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Oil light goes on and off
After an oil change if this keeps up replace the oil pressure switch it may not be sending a good signal. You may need to use a good flush to clean out the oil galleys.
Jun 29, 2009 | Little Giant 3e 12ny 1/15 Hp, 33 Lpm, 230v...
I am getting a lot of vibration from my pump
there is a bad bearing inside that has worn out and causes vibration and excess heat, when it frees up it will spin quiet for a little then bind and vibrate again. need to replace bearing.
Jun 20, 2009 | Little Giant 2-MDQX-SC Inline Pump
Little giant submersible water pump (model 5-mspr) is low on oil...what type of oil should I use to top up the oil level???
You can use a dielectric oil available at most motor repair shops. It is of the utmost importance to make sure the cord seal is in good condition and well sealed
Apr 22, 2009 | Pool & Spa
Plumbing Logo
110 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
