Hope this has what you're looking for.
http://esupport.sony.com/US/p/model-home.pl?mdl=DVPSR200P&LOC=3#/manualsTab
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
There are may possibilities, but these are some of the basic things to check.
Could someone have turned the color down?
You can go to the setup menu and "Reset" the player to the factory settings.
Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
Are the cables in good condition?
No breaks, loose connectors, they weren't smashed under a piece of furniture?
Have you tried a different set of cables?
Does the same thing happen?
Did you "Reset" the DVD player?
Maybe the DVD player is bad?
Does it work OK, or is it black and white too?
Maybe the connectors on the TV are bad?
Is there a custom setting on the TV for that connection?
On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
Best wishes,
-Greg-
SOURCE: Hi, I need to unlock
THere was some problem, with the chat...I was not gettin gyour messages
1.Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
SOURCE: How to turn off the closed captions on my sony dvd
I had the same problem so i simply turned off the CCD on the tv itself and no more captions!
SOURCE: How can I unlock Sony DVP-SR200P DVD Player
can sony sr200p-dvp be connected with external 40w speaker for listening music.
