Question about Carrier Heating & Cooling
I have a 4OQNC030---3 split carrier epressin unitl on the wall the fan will run until you put the A/C on and everything go's off. Gas pres is good on outside. the greeen light is going on & off, what could be going on with this unit. thanks for your help.
    New Friend:
  • 7 Answers
First ting to check is if you have it on the right MODE AND THEN TEMPR. SET POINT.,usuali on heat mode take 2-3 min until the temp. on the indoor coil is high enough to switch the fan
Posted on Jun 27, 2009
3 amp fuse blows when call for gas after pilot runs for 30 seconds
check the blower motor for seized of burnt out. Fuses blow because of excess current draw and in this case if the fan is not starting everything will stop. The gas will be set so that if the fan is not running the gas will not be allowed to turn on
Nov 21, 2014 | GE Carrier Bryant Payne 1/3 Hp 115v Blower...
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
My older Cozy cf353c counterflow wall heater gas shuts off pilot after it has run a while. I replaced the bad fan switch thermostat[ fan would not run untill changed] but not the other lemit switch . Could...
first have the heat exchanger inspected for a hole or crack, if there is an oval to round adpt. on top of unit or an elbow in vent this can cause the heat exchanger to split open and also cause what you are talking about.
Jan 14, 2010 | Cozy (W352E) Heater
HAD Carrier Digital unit, did not like, purchased Hunter, which I could not get to work Now I have extra colored wires hanging from the wall that came off the carrier that I did not tag.
Put the carrier unit back on the wall and connect the colored wires to the designated terminals.
R-Red, G-green(fan), Y- yellow and so on until they are all reconnected.
Manufacturers controls are designed to operate their units and sometime have more control options that require the extra wire you experienced with the off brand unit you purchased. Take it back and get the instruction manual out for the Carrier unit and learn to like it. If you have aZone System it is the only cotrol that will work with your system.
Oct 23, 2009 | Heating & Cooling
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Have a carrier dual gas thermal pump everything works fine diconnected thermostat to srew back plate into wall thermostat seem to work but can'T get ANYTHING going, funance , heat, or pump.
Blown fuse in Air Handler. It should be on the fan board inside the unit. 5 amp auto fuse replaces it and it will be ok. Russ. Happens all the time dont worry about it
Jul 18, 2009 | Heating & Cooling
Air con runs for 5 mins then stops, unit outside still going
ok depending on what part of the world your in and the season . Winter: most split systems are designed around a set given temperature of operation , if this is a heating problem the what you are experiencing is the system going into deforest . bare in mind that those carrier splits are manufactured in china and are designed for about 35 deg C in summer and +5 in winter , anything out of this temp range will cause this , especially if it is running on freon 22 , in-which case it sounds like its short of gas to me . if its a new R410 a system , then check your filters and if they are clean and its still doing the same then it too is short , in each case a refrigeration mechanic is required.
May 11, 2009 | Carrier 36KCARMS Air Conditioner
York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Oct 21, 2008 | Sanyo 09KS51 Mini Split Air Conditioner
Carrier air conditioning unit #38ckc042
Yes, the wires for your thermostat are low voltage 24volts, and there is a fuse that protects it, now if the fuse is gone, nothing will work until you separate the wires and put a new fuse, the fuse is inside the ac unit, if you cant find it, that means it doesnt have one. there for need to check voltage at the transformer.
May 08, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
