Question about HP Photosmart 2610 All-In-One InkJet Printer
Scanner says I need to install software
Scanner software was installed. Printer works, fax works, copy function works, cannot get the scanner to work. Please help!
  • 221 Answers
To make your scanner work use HP image Zone (included in your install cd or downloadable from hp's website)
Hope this helps
Posted on Jun 27, 2009
The scanner function on my Canon D480 has not worked since the installation.
Go to the scanner company website and see if there are drivers available for download. Sounds as if you may not have the proper drivers installed.
Jan 07, 2013 | Canon imageCLASS D480 Black and White...
After installed the Window 7, MF4360dn scanner is not working!
Hi there
Not work you need to find the windows 7 printer driver for it and it could be a job trying to find one as they are still selling there printers with xp drivers only, sorry.
Feb 21, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Printer works, scanner/copy does not
The problem could be because of ONE out of TWO problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 24, 2010 | Dell 924 All-in-One InkJet Printer
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
I bought the Intellifax 2480C. I just tried to install the software It installed printer driversI cannot use scanner I try to install disk 1 in the downloaded stuff I get "An error occured during the...
Use the software that came with the machine. A fax machine will appear as a printer in your printer folder. To get the scanner to work, you can use most software that you probably already have installed on your machine i.e. MS Works, Word, MS Paint, Corel by using the IMPORT from camera or scanner function on the software and choosing your Brother machine as the source.
Jun 27, 2009 | Brother IntelliFax-2480C Fax
Scanner has stopped functioning
ou need clean install . disconnect scanner remove all software in the add/remove area and go to device manger and remove scanner form list. then install software first,rebot, before installing scanner.should work then and for technical support contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
I just got a new Dell Windows Vista Laptop. I currently have a Brother 7420 printer, fax, scanner, copier combo. I can't get the scanner to work. Please HELP... Thanks, Pam
I presume the print and fax parts work. Can you make a copy? Have you checked the driver software? The CD that came with the equipment usually installs the scanner software as well. try reinstalling the software and see if it works.
Dec 01, 2008 | Brother MFC 7420 All-In-One Laser Printer
Scanner
Download and install full software and driver package for your machine from brothers web site, it sounds like you have installed the print drivers but not the scanning software.
Oct 27, 2007 | Brother MFC-5440CN All-In-One InkJet...
My scanner just quit
Need scanning software installed, go to brother web site and find full software and driver download package for your printer (under drivers) and install as instructed by program, you should unistall old driver setup first if enconting problems with new install, there is a uninstall on brother web site too
Oct 19, 2007 | Brother MFC-3240C All-In-One InkJet...
Errors
Hi Jean, The issue can occure only when the HP printer is not gettting enough power supply or the scanner bulb is not getting heated up properly.. You can isolate the issue by directly connecting the printer to wall jack and powerup the printer and try to make a copy so that we can check the copy function as the copy,scannig and FAX use the same scanner bulb to performe all functions.. If the copy does'nt work try to lift the scanner lid and check if the scanner bulb is lit and the scanner machinasium is moving fine or not .. lift the lid and press scan button to check the functionality. If the printer is connected to a surge protector or power strip this will some time fail to provide the required power supply to the printer so connect it to wall outlet and check with the issue.. There is also a FIRMWARE UPDATE RELEASED BY HP to fix the some of the scanner failure and receving faxes issue with HP 6110 All-in-one Here is the weblink to download and install the firmware update just click on the link to open the download page and then click on download and select save to save the patch to computer and run it to install the update make sure that the printer is connected and turn on while installing the patch The link to download: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14700-3&lc=en&cc=us&dlc=en&product=79477&os=228&lang=en Hope this will fix the issue.. If the issue is with the scanner failure message try the instruction in the below weblink: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en Wish you success Jean Regards, Barret
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
305 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
