Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a Hotpoint 25' sxs ref HSS25IFMCWW and the
I have a Hotpoint 25' sxs ref HSS25IFMCWW and the fan in the freezer wont run. Ive replaced it and it still wont run. All else seems fine, just wont circulate the cold air
  • 14 Answers
SOURCE: Freezer just not getting cold enough
The defrost heater element is bad, Do you know enough engineering to tackle the job ? You will need some hand tools and a spare Saturday afternoon .. Alternaively you could call a technician...
Posted on Sep 17, 2007
fridgetech
  • 473 Answers
SOURCE: Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Posted on Oct 10, 2007
  • 1462 Answers
SOURCE: cold air circulating fan
behind back panel inside freezer. take back panel off
Posted on Oct 20, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
tborn6
  • 700 Answers
SOURCE: GE Model GSH22JFTA Top of Fridg and Freezer not cold
check the door gaskets for air leakage
Posted on May 21, 2009
Whirlpool ref. panel light will not stay on. how do I make it stay on
Sounds like a machine operating ok. Buy a nightlight or contact the manufacturer for a user manual.
Jun 01, 2015 | Whirlpool ED5FHEXVS - Ref Sxs 25 - Sxs...
Ffa52 hotpoint diamond freezer running too warm
change condenser fan clean condenser coil dust at bottom of ref stopping cooling processes.Just like if you put cardboard in front of your car it will over heat or if fan is not blowing air on condenser coil
will not cool it fan and coil at bottom of ref. remove back you will see the dust pet hair a big problem with ref.
Mar 04, 2015 | Hotpoint Refrigerators
I have a hotpoint RF64p fridge freezer.... it wont freeze or chill... the pump is running and the light goes on.... i was thinking of replacing the thermostat in the fridge compartment but i notice there...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 13, 2011 | Hotpoint FFA60 Bottom Freezer Refrigerator
Top freezer works bottom refrig. does'nt
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | Hotpoint RTA41 Top Freezer Refrigerator
Water keeps dripping out of ice maker line over filling ice tray wont stop dripping
Leo Ponder
imufo2
Jul 29, 2011 | Hotpoint (HSM25IFTSA) Side by Side...
The bottom part of my hotpoint fridge is not working and not keeping the food cold ,how do i fix it?
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 28, 2011 | Hotpoint Refrigerators
Freezer part works fine, but the refrid won't cool?
The freezer is the only place that has cooling coils (condensor) the ref side steals air by way of a fan and duct from the fzr side. But in my experience the fzr i the last to go when an ref is low on freon. Also make sure the external coils are clean and the fan is running on the external side (if equip) coils are usually under the ref if it has a fan and is accessed on the bottom back by removing a cardboard access usually black. This cardboard looks flimsy but it is very important to reinstall it. It directs the air flow across the coils. after removing this you can plug your ref up to make sure the external fan kicks on with the compressor if not the fan is bad and needs to be replaced. always be careful with electricity...
Aug 08, 2010 | Hotpoint Refrigerators
GE SXS Fridge/Freezer
if the fan in the freezer compartment is not running theres a problem.
verify power to the fan motor, if present replace fan motor.
if not hopefully theres a wiring schematic/diagram so you could trace that circuit back to the control board and verify whether thats bad or not..
WR55X10942 - BOARD ASM MAIN CONTROL
generally though if the fan by the compressor is running the fan in the freezer should also be spinning and have power..
by the way, it states in the parts listing that it is a dc motor
WR60X10074 - Motor DC Evaporator Fan
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | GE GSS20IEP Side by Side Refrigerator
Freezer not getting cold enough
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
GE sxs Not Freezing
See if freezer fan is running when the unit is on. If you hear no fan when it's running. You probably need an evaporator fan motor.
Also check for ice or frost build up around fan.
Nov 12, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
105 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
