Error light will not stop blinking on my receipt printer; CT-S300. No manual so do not know any troubleshooting techniques. Help?
  • 221 Answers
Hello
This is the direct link to the manual:
http://www.citizen-systems.com/support/downloads/CT-S300UM5_201.pdf
You will probably find what you need inside
Posted on Jun 27, 2009
Printer won't stop feeding paper Citizen CT-S651
if its printing ~@{}{@@ZXXCZ wierd things then its a driver problem and you need to reload it
Oct 11, 2013 | Citizen CT-S300 Printer
Ct-s300 printer is printing a blank spot down the receipt
Sounds like the heating element is covered or broken in that spot.
Feb 14, 2013 | Citizen CT-S300 Printer
Paper keeps feeding after the print of the page
First I would look carefully at the site you are printing from, some will not let you select pages to print.
somesites will have "printer friendly" that you should select otherwise you print ever page fir that website.
next see if you can view PDF before printing then select only the ones you want.
in conclusion the problem appears to be not with your printer but the web pages
Aug 08, 2012 | Citizen CT-S300 Printer
Installed the driver and printer not working
Please click here to view my Tips on troubleshooting Printer PC connectivity.
Apr 25, 2012 | Citizen CT-S300 Printer
Error light blinking Citizen -S300 printer
  • High-speed (200 mm/s) printing
  • Longer cutter life (2 million cuts) delivers lower maintenance costs
  • Greater reliability delivers longer life & lower maintenance costs
  • Wider paper width allows printing of additional information & larger fonts
  • Interchangeable interfaces
  • 2D barcode (QR-code and PDF417) support allows wider applications
  • Built in buzzer provides audible alert without adding extra cost devices
  • Built in power supply eliminates unsightly "brick" and frees up space
  • Cash drawer kick-out external device port supports 2 cash drawers
  • 2-color printing supported (when specified paper uused)
Aug 16, 2011 | Citizen CT-S300 Printer
The device will not close, It looks like there are two teeth sticking out on the inside that is not allowing the door to close. any ideas? We really need some help here. THanks . John
The solution to this problem is not really intuitive, but pretty easy. The small blade inside the CT-S300 occasionally gets stuck and must be manually retracted. You will need to obtain a small Philips-head screwdriver. Insert the screwdriver into the "cutter lock release fitting eye-hole" located on the right-hand side of the unit. Crank the screwdriver to the right several times to retract the blade. Look down inside the unit as you crank
Oct 09, 2010 | Citizen CT-S300 Printer
Canon S300 printer. 7 orange blinks, 1 green. I
According to the manual found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=6609
7 orange lights represents a bad print head, and the printer will need serviced or replacement. Since printers are so cheap lately, I would just go shopping. Hope this helps! Thanks!
Oct 21, 2009 | Canon BJC S300 InkJet Printer
Have a Canon S300 Bubble Printer. Light keeps flashing doesnt print.
Watch the blinking of the light and tel me what the sequence of the blinks are they give a code for troubleshooting also which light is blinking?
Jun 28, 2008 | Office Equipment & Supplies
HELP!
hi, the blinking is caused by a fault in the printer, means it needs to be serviced, its usually more expensive for them to fix it than buying a new one, but you can get there number off the canon website.
Happy New Year
John
Dec 28, 2007 | Canon BJC S300 InkJet Printer
Low voltage error indicated
Bad main PCB, send in for service. 95.00 Flat rate repair.
Agson 856-751-9048
Aug 09, 2006 | Citizen CT-S300 Printer
319 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
