Question about H.K. Porter Cooper 0190AC 4 Lb. Series 2000 Bolt Cutter
I broke one of the handles. how can I get a replacement handle? for my H. K . Porter Series 20000 24" bolt cutter?
Bolt broke off of adapter and blade. I replaced bolt and it broke again. So i replaced the bolt and adapter and now making a loud knocking sound this is on my cub cadet walk behind sc500z
Hi Diana:
I'd suggest that you pull the spark plug lead so it does not accidently start, and then try this.
Place the mower at a height where you can easily see under it. I use the tailgate of my pickup trucl.
If you put the handle inside the bed of the truck you can put a weight on the handle so the deck is tipped up. With the spark plug disconnected (or even removed) rotate the blade. Chances are that the knocking sound will be from the blade hitting the deck. It is possible that the bolts keep breaking because the blade is not seating properly.
I'm guessing that once you can see under the mower you will find the problem.
Aug 11, 2016 | Cub Cadet Garden
Superior tool 37100 blade replacement
From Superior Tool Website, look up the tool, then click on "How to Use".
Blade Replacement:
1. Remove large pivot bolt and nut
2. Slide blade down through handle
3. Remove one (1) end of coil spring
4. Remove "E" clip from 1/4" pivot pin,
remove pin and blade
5. Install in reverse order
6. Torque nut until tool ratchets correctly
Mar 13, 2013 | SUPERIOR TOOL CO superior tool 37100...
2002 Chevy Tracker ZR2 (small suv) outside, left, drivers door handle broke
You should have someone experienced with you to do this type of job, due to the complex series of tasks involved
Mar 04, 2013 | Cars & Trucks
Are bolt cutters safe to use around live electricity?
only if they have fiberglass handles. these are the kinds that are used in emergency situations
Jan 16, 2013 | Cutter Tools
Both handles on 1996 grand prix broke how do I replace them
there should be a couple star bit bolts on inside of door behind the handle
Dec 05, 2012 | 1996 Pontiac Grand Prix
The regulator knob is broke. Where can I get a replacement? Replacement parts diagrams do not show the knob as replacement part.
You can't buy the regulator knob as a seperate part, you have to buy the entire manifold; Porter Cable part number N003001. Shop around on parts sites as these cost around $70 plus any shipping and handling. Depending on how often you have to change the regulated pressure output it may not be worth replacing.
Jan 20, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Open a suburban door when both handles are broke
ok easy to fix. remove door panel. when u have the replacement parts. start with the outside handle, remove the bolts, undo the bar, remove the handle. same with the inside handles
Mar 14, 2010 | 1999 Chevrolet Suburban
In need of a replacement handle
You should be able to buy the top section of the handle. What kind of mower is it and what is the model number? It should be on the rear of the deck.
Jun 10, 2009 | Great States Corp. 16 In. Scotts Elite...
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Crock Pot Lid Handle
http://search.hardwarestore.com/?query=Rival++38601+Smart+Pot+6-Quart+replacement+handle
You can get one here.
Feb 25, 2008 | Rival 38601 Smart Pot 6-Quart
H.K. Porter Cooper 0190AC 4 Lb. Series 2000 Bolt Cutter Logo
536 people viewed this question
Top H.K. Porter Cutter Tools Experts
Kim Baker
Kim Baker
Level 1 Expert
Are you a H.K. Porter Cutter Tool Expert? Answer questions, earn points and help others
